Comments please
Old Apr 24, 2008 | 11:32 AM
dont_tri's Avatar
Default Comments please
So I got a tremendous deal on a freshly rebuilt short block. Since I'm going turbo I figure this would be a good addition to my turbo project. However, the rebuild consist of a b16a2 rebuilt with the following internals CTR piston’s .25 over, OEM rods, OEM bearings, OEM water & oil pump and all OEM seals. Would this be a mistake to use CTR pistons going turbo? Not going to be pushing a lot of boost my goal is 300 hp maybe 350. I have a 60trim turbonetics with a .63 a/r. Currently have 560cc injectors might be going 1000cc but after doing research 560cc are good up till 100hp per cylinder. My cams are going to be 95 GSR cams. Any info and / or comments are very much appreciated. Thanks
If you need more information please feel free to ask.
Old Apr 24, 2008 | 08:08 PM
TheShodan's Avatar
Moderator
You're still using internal components that can't take that amount of power, even if it is rebuilt. Using CTRs in a B16 don't help, either. You've got a great N/A setup there, throw some cams in it, and call it. Or sell it, and substitute this w/ another block to get that power.
Old May 1, 2008 | 09:02 AM
dont_tri's Avatar
So basicly I should ditch the deal and invest in some eagle rods, cp 9.5.1 pistons and sleeve the b16 and then call it the day.
99_EM1
20
Dec 5, 2010 08:26 PM
UserX826
Mar 13, 2009 11:58 AM
phantomh22
28
Jun 3, 2008 03:25 PM
highrevnef
Jun 10, 2005 12:12 PM
Bulldogg83
Nov 30, 2003 04:02 PM
