cometic headgasket blown
Old Dec 15, 2004 | 07:14 AM
Gsr_Hybrid_theory's Avatar
Default cometic headgasket blown
so... the last couple of days ive been noticing coolant in my gsr goin away,....
so i filled it up.. (with my yellow coolant filler upper)... .. the t-stat opened... .. let fans run 2x.... .. saw bubbles comin from the ... filler??
looked at the temp gauge- sitting normal....smelt coolant... shut car off... coolant bubbled in rad... started it... coolant EVERYWHERE.. ahahha what do i see now?
cars idle drops to like 400... white smoke out tailpipe... and that was it
popped the plugs out
cyl 1-3 1/4" of coolant in it... pistons white washed...
long story long... ordered a new ehadgasket from golden eagle...
even better: tghis weekend= coldest part of the year .. in the 0's to teens GREAT
Old Dec 15, 2004 | 07:23 AM
Full-Race Geoff's Avatar
Default Re: cometic headgasket blown (Gsr_Hybrid_theory)
which cometic head gasket was it? I have used both and found their standard MLS head gasket works better than the fire ring gasket
Old Dec 15, 2004 | 07:29 AM
b18bturbo's Avatar
Default Re: cometic headgasket blown (Full-Race Geoff)
your not the only one Geoff the MLS vs the HP gasket the MLS works 100 times better in my opinion the HP gasket does work nicely with stock sleeves but with aftermarket i dont really consider using the HP gasket with fire rings
Old Dec 15, 2004 | 07:37 AM
Default Re: cometic headgasket blown (b18bturbo)
off hand i forget.. its a 84mm gasket... w/ 3 layers...but hey... whatcha gonna do..
if this 1 fails im going to ring someones neck
maybe my girl for telling me to sell it CONSTANTLY
****and it was only 13lbs****
Modified by Gsr_Hybrid_theory at 8:50 AM 12/15/2004
Old Dec 15, 2004 | 08:37 AM
MooreBoost's Avatar
****, I just ordered an HP for my D16. Im shooting for 300whp, should I change my order real quick?
Old Dec 15, 2004 | 09:45 AM
92HB_HB's Avatar
Default Re: cometic headgasket blown (tegunderpressure)
my cometic MLS gasket has been leaking on me as well.. its not blown, but just leaking.. I"ve retorqued the head, but if that doesn't solve the problem.. i'm goin w/ an OEM GE overbored HG..
ARRGHH.. I hate HG problems.. so much work to do..
Old Dec 15, 2004 | 10:49 AM
Mr. Roboto's Avatar
I had issue's with Cometic Hi boost headgasket, but that had to do with my Darton sleeves and and the design of the cometic headgasket (at least thats what I was told) just didn't seal properly.
Old Dec 15, 2004 | 11:42 AM
Turbo E's Avatar
get some ARP head studs while you're at it
Old Dec 15, 2004 | 11:50 AM
MooreBoost's Avatar
Default Re: (Turbo E 604)
I PM'd earl and he said he used MLS on every one of his builds. I had my order switched.
Old Dec 16, 2004 | 09:55 PM
PrettyLude's Avatar
the mls and oem are good enough to use, the high boost i had i didn't like it too much, could never seal right
Old Dec 16, 2004 | 11:04 PM
FredoSP's Avatar
Question where any of your spark plugs really white?
Also, where you losing coolant in your reservoir tank? I have a cometic HG and I noticed that even with light driving (car doesn't over heat at all) Im losing a drop in the over flow tank. Every 2 weeks I have to fill it up a drop, Id say about 6 oz. I wonder if my HG has a tiny leak somewhere?
Did you have any of the above symptoms?
Old Dec 17, 2004 | 03:30 AM
Default Re: cometic headgasket blown (FredoSP)
plugs werent white- soaked black...
pistons were white or... at least a "tan"
wasnt loosing alot of coolant in the overflow.. more in the rad.
Old Dec 18, 2004 | 01:35 PM
BEEYOND's Avatar
screw the COMETIC... get a stock OEM.... 80% of the Cometic we have used LEAKED... not blown up, but LEAKS....
COMETIC
Old Dec 18, 2004 | 01:56 PM
Default Re: cometic headgasket blown (lsvtecpower)
update on gasket:
fk cometic - heres hope for golden eagle
heres some nice pics for ya
- mmm nice valve covre gasket... looks like co-agulated turkey gravy from thanks giving - yeah thanks alot!
Old Dec 18, 2004 | 02:20 PM
FredoSP's Avatar
holy crap!
Old Dec 18, 2004 | 03:29 PM
93LSivic's Avatar
I have used Cometic for some time now, never once had a problem in my personal motors (****, Ive even reused them in my motor before) or any of my customers. All types of engines, 200+ n/a, 500+ turbo.
Both MLS and HP have been good to me and my customer.
Most of the time when there is a hg failure its due to other circumstances. If your blowing them dont blame the gasket and start diagnosing your problems elsewhere.
Old Dec 18, 2004 | 06:59 PM
92HB_HB's Avatar
Default Re: cometic headgasket blown (93LSivic)
pics dont work.
Old Dec 18, 2004 | 07:38 PM
S2KP's Avatar
I've never had any issues with Cometic MLS....only one i've ever used too, other than OEM.
Old Dec 18, 2004 | 09:20 PM
Beanbooger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
Most of the time when there is a hg failure its due to other circumstances. If your blowing them dont blame the gasket and start diagnosing your problems elsewhere.</TD></TR></TABLE>
Voice of reason
Old Dec 18, 2004 | 10:02 PM
BoostedJeff's Avatar
Default Re: cometic headgasket blown (Beanbooger)
Just replaced my cometic with an OEM honda today, due to my cometic blowing with only 1,500 miles on it
Old Dec 18, 2004 | 10:55 PM
ATS*Mark's Avatar
OG triple OG
Default Re: cometic headgasket blown (BoostedJeff)
ive gone threw 2 cometics and im on my third as of tonite . this one was the worst but wasnt fully blown . i drove on it for a few thousand miles and no milk shake . but it would literally shoot out of my overflow tank if i boosted . when i drove to get my cf hood i took my stock hood off. when i boosted i got a nice shower of coolant all over my windshield lol.... i even had my head resurfaced and it wasnt warped so i dont know what to do now.....i hope this solves my problem.
Old Dec 18, 2004 | 11:04 PM
Default Re: cometic headgasket blown (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">ive gone threw 2 cometics and im on my third as of tonite . this one was the worst but wasnt fully blown . i drove on it for a few thousand miles and no milk shake . but it would literally shoot out of my overflow tank if i boosted . when i drove to get my cf hood i took my stock hood off. when i boosted i got a nice shower of coolant all over my windshield lol.... i even had my head resurfaced and it wasnt warped so i dont know what to do now.....i hope this solves my problem.</TD></TR></TABLE>
had the same exact problem, boost was creeping into my water jackets and shooting coolant out of the overflow EVERYWHERE in my engine bay. I pulled the head today, to find that most of the damage was done to the 3rd cyl on the headgasket. Cometic gets the big from me. trying OEM honda this time, make that will do the trick.
Old Dec 18, 2004 | 11:27 PM
ATS*Mark's Avatar
OG triple OG
i dont know how to read gaskets at all....i wish i could see where mine went wrong.
Old Dec 18, 2004 | 11:35 PM
SOHC_MShue's Avatar
bump for learning how to read gaskets. I can never tell with mine either. OEM hasn't been working for me either...
Old Dec 18, 2004 | 11:48 PM
Default Re: cometic headgasket blown (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">bump for learning how to read gaskets. I can never tell with mine either. OEM hasn't been working for me either...</TD></TR></TABLE>
just look at your headgasket, where it sits around the cylinder. If the black is looks like it is torn away, you know your headgasket its blown/on its way out.
