Colder Thermostat?
Old Feb 26, 2006 | 06:19 PM
MBlake55's Avatar
Default Colder Thermostat?
I was wondering wat kind of colder thermostat i need for my dseries turbo setup becuasei figure that i will be running the motor a lot hotter and i need a colder thermostat to kick the radiator on sooner, wat temp should i get and/or wat brand thanx
Old Feb 26, 2006 | 09:18 PM
Boostage's Avatar
Default Re: Colder Thermostat? (MBlake55)
I have always been a fan of stock thermostats on any car I own (not just honda). manufacturer's usually set it were it supposed to be for proper operation. too cool might hurt more than it helps, but you can always just add an oil cooler.
Old Feb 27, 2006 | 06:07 AM
MBlake55's Avatar
Default Re: Colder Thermostat? (Boostage)
are you sure that i shouldnt get a colder thermostat with a turbo setup like 10 degrees colder?
Old Feb 27, 2006 | 06:21 AM
wade's Avatar
Old Feb 27, 2006 | 09:10 AM
Civicman86's Avatar
Default Re: Colder Thermostat? (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">.</TD></TR></TABLE>
I run stock thermo on my d series and its fine. Upgrade later if you need. Its not an expensive part if you do need it down the road. I think a bigger radiator is needed before thermo if you dont have it already.
Its spelled "what" not "wat", by the way
Old Feb 27, 2006 | 10:45 AM
seen4ever's Avatar
Default Re: Colder Thermostat? (Civicman86)
i recently switched from a 160 degree thermostat to a honda OEM thermostat. upgrading a thermostat is really just a waste of money if you have the stock fan switch, plus when you think about it, the stock ecu doesn't stop its cold start correction until the engine coolant is above 185 degrees, so if you run a stock ecu backed standalone, if you get your coolant too cold, you expletive yourself in terms of tuning.
Old Feb 27, 2006 | 02:46 PM
wade's Avatar
Default Re: Colder Thermostat? (seen4ever)
who are you to talk? you are a mustang guy
Old Feb 27, 2006 | 04:43 PM
Tchleung's Avatar
I have my fan wired to a swithc which I have on almsot always unless it's on a cold start. and I run a 160*thermostat vs the stock 170-180. runs a tad cooler. I like it. tuning it was a breeze. Never have any troubles.
Old Feb 27, 2006 | 05:28 PM
Muckman's Avatar
Moderator in Chief
Whatever you use dont use a cheapo Autozone Tstat.
Old Feb 28, 2006 | 04:14 PM
MBlake55's Avatar
Default Re: Colder Thermostat? (Muckman)
so wat would be the best suggestion? hook up a switch to my radiator fan so that i can kick it on when the temp rises?
Old Feb 28, 2006 | 04:25 PM
Tchleung's Avatar
with an OEM thermostat, and a everythnig else in good worknig condition, the temps will not rise
Topdawgg
Jun 2, 2011 03:41 PM
1baddcivicsi
Oct 3, 2006 04:55 PM
h22 booster
Sep 5, 2006 06:40 AM
itr_dc2
Jun 22, 2004 01:14 PM
Dancing is Forbidden
Jul 20, 2003 07:42 PM
