colder spark plugs......same info apply?
Old Jan 18, 2003 | 08:45 AM
rjardy's Avatar
Default colder spark plugs......same info apply?
i did a search and came up with this
https://honda-tech.com/zerothread?id=274880
just wondering if that part number is still the same for the D series block?
what plug are the D guys running?
thanks again guys
Rob
Old Jan 18, 2003 | 08:53 AM
rjardy's Avatar
Default Re: colder spark plugs......same info apply? (rjardy)
bump please
Rob
Old Jan 18, 2003 | 09:39 AM
rjardy's Avatar
somebody has got to know this
Rob
Old Jan 18, 2003 | 02:33 PM
rjardy's Avatar
back up before i get off from work. People please!!!!!
Rob
Old Jan 18, 2003 | 04:15 PM
rjardy's Avatar
this is starting to look like its in the classifieds
Rob
Old Jan 19, 2003 | 07:29 AM
rjardy's Avatar
up agian
Rob
Old Jan 19, 2003 | 07:36 AM
boostaholic's Avatar
I think you'll be fine with a 7 series plug. If i remember right, the d series motors uses a 5 series plug so technically one step colder would be a 6 series plug. All things being equal, i had better luck with the BCPR7ES plugs over the BKR7E.
Old Jan 19, 2003 | 07:39 AM
rjardy's Avatar
Default Re: colder spark plugs......same info apply? (boostaholic)
finally a reply!!! so that part number is the one i need yes?
Rob
Old Jan 19, 2003 | 07:46 AM
yes, either the BCPR7ES or BKR7E will work.
Old Jan 19, 2003 | 07:50 AM
rjardy's Avatar
great thanks so much
Rob
Old Jan 19, 2003 | 10:42 AM
mos's Avatar
mos
I think bcpr6es is stock for my d-series car. So 7 might only be one step colder for you, not two steps.
Old Jan 19, 2003 | 11:17 AM
rjardy's Avatar
Default Re: colder spark plugs......same info apply? (mos)
where can i find out whats stock on a 00 ex (d16y8)?
Rob
Old Jan 19, 2003 | 11:41 AM
Stock plug code should be on a sticker under the hood or on the timing cover.
mustang5.slow
Mar 4, 2007 04:39 PM
SPOON_BeIgHtEeNsEe
May 12, 2004 02:00 PM
