Colder plugs for mini me and boost, which plug do I use????
Old Jul 14, 2004 | 06:38 AM
Akiraboy's Avatar
Default Colder plugs for mini me and boost, which plug do I use????
I have a d16a6 bottom end and a d16y8 head. I am currently using spark plugs for the d16y8 head. I noticed a hesitation or missing(misfiring) under harder acceleration. Someone mentioned that I should use colder plugs. I agree to this but should I use plugs meant for the head or for the block?
Since its a mini me I am not sure which one to use? I am currently using stock repalcement NGKs from the same year as my 1999 d16y8 head but should I be using plugs meant for the d16a6?
I have been running the y8 plugs NA for a while now without problems. I just went to boost 1 week ago and about three days ago I started to notice this problem.
I am asking cause I need to go 1 range colder and I need to order the correct plugs.
So either I go 1 range colder on the d16a6 plugs or 1 range colder on the d16y8 plugs.
I also searched but I did not find info on this subject.
thanks
Old Jul 14, 2004 | 07:12 AM
tgreaves's Avatar
Default Re: Colder plugs for mini me and boost, which plug do I use???? (HONDACIVICWAGON.COM)
Im using ngk zrf7f-11's in my boosted d16y7.. The stock plug is a zfr5f-11 so im running 2 heat ranges colder than stock..
Old Jul 14, 2004 | 09:28 AM
mos's Avatar
mos
Default Re: Colder plugs for mini me and boost, which plug do I use???? (tgreaves)
The d16a plugs are bcpr6e-11 IIRC. The zfr plugs have a (ISO projected) slightly longer nose. You're probably ok with either.
Old Jul 14, 2004 | 12:41 PM
Akiraboy's Avatar
Default Re: Colder plugs for mini me and boost, which plug do I use???? (mos)
ok, then I may try goin with the y8 plugs but 1 colder range 1st, then see if I still have that hesitation problem. thanks
DOUBLExDEUCEx22
Feb 18, 2009 02:43 PM
CALC!_JUST_du_IT!
Jan 8, 2007 07:28 PM
Hazem
11
Dec 7, 2004 04:59 AM
DaveSi677
Oct 31, 2003 09:13 PM
Racerage1
Apr 3, 2003 09:28 AM
