Codes 17 & 20
Old Sep 15, 2006 | 01:14 PM
Project_SOHC_EX's Avatar
Default Codes 17 & 20
Car is a 92 Integra with a 94 gsr swap excluding the ls cable transmission. Computer is the stock obd-1 P72. As stated the car is, was rather throwing codes 17 & 20. Codes went away but the VTEC does not seem to becoming on in the car, so something is wrong, car revs all the way to 8100rpms but the vtec does not sound like it's popping. Or is it because of the long gears from the ls transmission. Also a lot of heat comes from the firewall close toe the transmission. Need some help.
Old Sep 15, 2006 | 03:23 PM
50SaysHeEatsIt's Avatar
Default Re: Codes 17 & 20 (Project_SOHC_EX)
because you are throwing a code 17 (VSS) vtec will not work . you need to fix that code 1st
Old Sep 15, 2006 | 04:15 PM
Default Re: Codes 17 & 20 (50SaysHeEatsIt)
Thanks. The VSS sensor is working but for some reason that caused the car to throw no check engine lights when before we had two. As I stated the vehicle also does not seem to engage VTEC or is that due to the longer transmission?
Old Sep 15, 2006 | 04:27 PM
Turbo-charged's Avatar
transmision will have no effect, hell if anything the long trans will make vtec feel stronger.
use a test light to see if its sending out the signal to the solonoid to determin if its electrical or mechanical
Old Sep 15, 2006 | 04:31 PM
I would say not at all. Try clearing the codes (1st see if they are still stored on the ecu but jumping the harness) then un hook the batt. if all else fails you can take the speed sensor out located on the back of the tranny right near the pass. side axle . It has 3 wires on it, i have heard of ppl cleaning them with carb cleaner... if that does not work try using (if you can get your hands on one) another speed sensor. Single cam ones also are compatible Good luck
Old Sep 15, 2006 | 04:32 PM
Default Re: Codes 17 & 20 (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">transmision will have no effect, hell if anything the long trans will make vtec feel stronger.
use a test light to see if its sending out the signal to the solonoid to determin if its electrical or mechanical</TD></TR></TABLE>
Old Sep 16, 2006 | 09:51 AM
mec. pedri's Avatar
code 20: electronic load detector ELD
code 17: vehicle speed sensor VSS
Pr0ject93hb
Sep 14, 2007 09:50 AM
nh4442
Apr 25, 2005 11:36 PM
shinoda
Apr 25, 2005 08:23 AM
Dc4turbo408
Oct 2, 2004 01:54 AM
ninety9ex
Jan 26, 2004 07:40 PM
