Clutchnet stage 2
Old Dec 12, 2001 | 08:51 AM
Speed PHreak's Avatar
Default Clutchnet stage 2
I'm going to be needing a clutch soon, i'm leaning towards the Clutchnet stage 2 Kit offered by importparts.com. I'm just wanting to get some feed back from anyone using this clutch on it's performance. Also, the kit comes with a clutch disk and pressure plate, does it come with the bearings also?
Old Dec 12, 2001 | 10:08 AM
austrian type-R's Avatar
Default Re: Clutchnet stage 2 (Speed PHreak)
I´ve the clutch kit + bearing kit (which is extra) at home. I bought it, because I´ve not heard ANY bad things on this brand. I got it from Importparts too, but I have´nt installed it yet. Very good price!
Old Dec 12, 2001 | 10:31 AM
maxim's Avatar
Default Re: Clutchnet stage 2 (austrian ITR)
What is the bearing kit for? I will be getting the CN stage2 pretty soon. Do I need one of those to put in my car?
Old Dec 12, 2001 | 10:37 AM
Default Re: Clutchnet stage 2 (maxim)
You'll prolly want the bearing kit. You usally get 2 bearings one that goes in you flywheel, and the throwout bearing. This ones important because if it;s not in good working order then you'll be working your leg engaging and disengaging the clutch.....
Old Dec 12, 2001 | 11:16 AM
sgT's Avatar
sgT
If the release bearing breaks, then the clutch cannot be disengaged.
Rgarding the clutchnet, its VERY SOFT, and it engages almost near the top.
Just things to keep in mind in case thats not what you are looking for.
Old Dec 12, 2001 | 12:40 PM
Damon B.'s Avatar
Default Re: Clutchnet stage 2 (sgT)
Yeah, the clutch feel is like stock, but the engagement point is at the damn top, takes getting used to.
Old Dec 12, 2001 | 12:43 PM
InfamousRS's Avatar
Default Re: Clutchnet stage 2 (CleanSi)
How much WHP and Torque can the CN Stage 2 handle?
Old Dec 12, 2001 | 12:57 PM
Ben Huynh's Avatar
Default Re: Clutchnet stage 2 (BLK94RS)
250lb/ft
Old Dec 12, 2001 | 01:07 PM
SiR Kid's Avatar
New User
Default Re: Clutchnet stage 2 (ben@importparts.com)
250 ft/lbs.... so 400+ hp? that seems ot be about the ratio on the Honda 4 cylinders....
What stage Clutchnet is a 6 puck solid hub kevlar or Copper/ceramic? That's what I'm interested in?
Anyone have a link for clutchnet info and pricing?
Old Dec 12, 2001 | 01:26 PM
Ben Huynh's Avatar
Default Re: Clutchnet stage 2 (SiR Kid)
Check here for info:
http://www.groupbuycenter.com/buy.as...ad&row_id=3946
Old Dec 12, 2001 | 01:44 PM
HXMan's Avatar
You can adjust the engagement point.
Old Dec 12, 2001 | 02:02 PM
D-SPEED's Avatar
Default Re: Clutchnet stage 2 (HXMan)
how can you adjust the engagement point ?
i just installed the stage 2 on my brother's (type autox) LS....the pedal is like stock, nice engagement though, and it is at the top like everybody has said. He bought his from importparts as well.
Old Dec 12, 2001 | 02:20 PM
lucas569's Avatar
Default Re: Clutchnet stage 2 (D-SPEED)
to adjust crawl under your dash and losen the nut for the clutch master cylinder and turn the brass rod, do it in very small increments cause just a little makes a big difference.
i was looking at he cm stage 3 but its kinda pricey, the clutchnet is so tempting at this price though! i'm not sure about the 6 puk although it has springs. wish lived near someone that had it.
ben is the clutchnet stage one closer to the cm stage 3? seeing that it multi/full faced but solid instead of 6 puk?
99hondadx
Mar 14, 2017 01:56 PM
DC4_Dad
Transmission & Drivetrain
Oct 15, 2014 05:12 PM
rebohn
Jan 4, 2004 10:11 AM
Audi RS4
Aug 28, 2003 09:33 PM
SamC
Jan 30, 2003 02:05 PM
