Clayed new engine. Is piston to head clearance of .030" OK?
Old Feb 16, 2003 | 06:21 PM
niedejb's Avatar
Default Clayed new engine. Is piston to head clearance of .030" OK?
Clayed the build I'm doing tonight since the pistons stick out of the F22b1 GE block (8.8:1 pistons and crowers...stock compression, but deck was milled when sleeved).
The valves didnt hit the clay (~.100" thick) with the vtec lobes locked. But the head (between the intake & exhaust valves) smushed the clay to .030-.035" using and old stock gasket.
Have no idea if thats good or bad. Any input?
Old Feb 17, 2003 | 12:35 PM
niedejb's Avatar
Default Re: Clayed new engine. Is piston to head clearance of .030" OK? (niedejb)
Anyone?
OK. What would be the typical piston to head clearance of a B,D, or H series?
Old Feb 17, 2003 | 06:07 PM
niedejb's Avatar
TTT for the evening helpers.
Old Feb 19, 2003 | 04:37 PM
niedejb's Avatar
One last bump before bolting the head on and trying.....
Old Feb 19, 2003 | 05:51 PM
Bnjmn's Avatar
If your rod bolts stretch more that that then you are in trouble (obviously). You should probably find a Helms manual to get this info.
Old Feb 19, 2003 | 05:57 PM
niedejb's Avatar
Default Re: Clayed new engine. Is piston to head clearance of .030" OK? (Bnjmn)
I have an OEM manual and it mentions nothing of the sort.
All I know is the pistons are the same compression and the block was milled after the sleeving (no milling on the head) and now the new pistons stick up above the sleeves.
Thats why I clayed it.
Just curious to what others have gotten away with for piston to head clearance.
Figured since this beast only goes to 6500 rpm I'd be safe with B/D equivelant spacing.
Old Feb 19, 2003 | 06:01 PM
b18bturbo's Avatar
run a .036 gasket from cometic and you should be okay. We ran in the same problem as well make sure you really check it vtec kicks it changes the valve clearance so make sure you lock it and test it correctl.y
Old Feb 19, 2003 | 06:05 PM
niedejb's Avatar
How thick is the stcok gasket, BTW?
[Modified by niedejb, 9:06 PM 2/19/2003]
Old Feb 20, 2003 | 02:43 AM
paulzy's Avatar
is there a procedure to clay the motor in the helm's book? How come I never came across this?
Old Feb 20, 2003 | 02:48 AM
niedejb's Avatar
Default Re: Clayed new engine. Is piston to head clearance of .030" OK? (Paul_Vang)
No. I used the how to from here:
http://www.c-speedracing.com/frame.php/
The clearance you find has to be compared to something (i.e. the specs in the OEM manual).
They dont mention the minimum clearance in the OEM manual.
Old Jun 21, 2004 | 11:50 AM
93H22ACX's Avatar
how did everything go with your setup? mine is sticking out too
Old Jun 21, 2004 | 04:57 PM
DRAGLS's Avatar
Default Re: Clayed new engine. Is piston to head clearance of .030" OK? (93H22ACX)
I have read that its a minimum of .100" to .075" vtec lobe
monster_c
Jan 12, 2012 10:48 PM
SilverEk3dr
Apr 30, 2009 07:53 AM
MatHadder
12
Mar 4, 2007 02:59 PM
GetSTROKED
Oct 19, 2006 03:39 PM
drunknbass
Aug 20, 2004 05:40 PM
