civic half core into dc2
Old Feb 14, 2010 | 07:13 AM
jne's Avatar
jne
Default civic half core into dc2
i am switching to a mishimoto 92-00 civic half core radiator to gain more room for the new turbo set up. but i've read somewhere that the upper radiator hose is smaller on a civic radiator? can anyone confirm this? thanks!
Old Feb 14, 2010 | 07:30 AM
IN VTEC's Avatar
Default Re: civic half core into dc2
I have a Koyo 1/2 width radiator and I used the same upper and lower radiator hoses and both have a snug fit.
Old Feb 14, 2010 | 07:40 AM
kyden's Avatar
the necks are smaller on d series radiators. but if you buy a mishimoto it should be a b series size on it.
Old Feb 14, 2010 | 09:15 AM
94VTEC2TONE's Avatar
he is correct i have a half rad also. and it fits great. only thing ur going to have problem with is the mounting point for the bottom of the rad. the one will fit but u need to make a bracket or something for the other post
Old Feb 14, 2010 | 10:35 AM
jdm inc's Avatar
x2
Old Feb 14, 2010 | 06:21 PM
Turbo-LS's Avatar
the mishimoto will work fine. im running mine with stock dc upper hose no problems. like stated above they come with the larger b series style not small like d series.
be sure to either use a shrouded fan like a stocker or fal or get a 14" zirgo fam that takes up almost 100% of the surface area. its going to need good air flow and fan to remove the heat. ive run all different size fans and with/without shroud and best results was with my zirgo beyond cool 14" fan
Old Feb 15, 2010 | 08:27 AM
blowededup's Avatar
^^ or he could just get the Mishimoto Fan Shroud made for the 92-00 Civic radiator he is buying... That would probably be best IMO.
Old Feb 15, 2010 | 12:49 PM
Turbo-LS's Avatar
well it would work fine but a 12" fan doesnt flow as much cfm as a 14" fan so a 14" fan would work better but the 12 with a shroud will work
eddie7978
Jun 18, 2017 09:36 PM
musicminister18
Sep 24, 2014 05:09 PM
bluemc
35
Dec 22, 2011 08:38 AM
Mr. JDM-GSR
Feb 10, 2006 05:12 PM
