civic 95 turbo problems
Old Oct 22, 2008 | 08:12 PM
junior_tm's Avatar
Default civic 95 turbo problems
i have a zc vtec sohc engine
i was driving like 4 months and it sucked water since then is making some wierd noise in the head like a valve is bent or somethin like that i still drive the car
now i installed a turbo kit on it and a lot of water is coming from the intercooler pipes
the car never got heated
i got a drag manifold
xs power wastegate
intercooler and pipes
greddy type s bov
dsm 450cc injectors with resistor box
p28 with crome gold (not tuned yet just chipped)
when i turn on the car it idles high almost 1 then i step on the gas and it chocks a little then white smokes come from the exhaust
what should i do should i get a new head and new hg? what gasket should i go for?
Old Oct 22, 2008 | 09:56 PM
teknohatchie91's Avatar
Default Re: civic 95 turbo problems (junior_tm)
wow.
Old Oct 22, 2008 | 10:48 PM
98exn20's Avatar
Do a compression check, if that is good do a leak down, between those two you should find your problem. also if your turbo is water cooled you may have a leaky seal in it. check the oil in your oil pan to see if there is water in it.
Old Oct 22, 2008 | 11:30 PM
junior_tm's Avatar
the turbo is not water cooled the turbo is a t3 from airresearch
Old Oct 23, 2008 | 08:00 AM
thatblkguy's Avatar
OEM headgasket and a rebuild of the head.
but like said before leakdown and cp test
Old Oct 23, 2008 | 08:03 AM
accord_raffi's Avatar
how are you getting water in your intercooler pipes??
Old Oct 23, 2008 | 03:34 PM
blwn95civic's Avatar
Default Re: civic 95 turbo problems (accord_raffi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_raffi &raquo;</TD></TR><TR><TD CLASS="quote">how are you getting water in your intercooler pipes??</TD></TR></TABLE>
^^x10000
the reason for the car idling and reacting weird is more thank likely your basemap. Basemaps are basically for starting the car until it gets tuned
Old Oct 23, 2008 | 06:46 PM
Default Re: civic 95 turbo problems (blwn95civic)
post a video of the noise in the head. If it's a tick, you might just have to redo your exhaust manifold gasket. It might be worth checking your iacv and fitv. You might just have to tighten the fitv or check the tps for your idle issue.
Old Oct 23, 2008 | 07:55 PM
junior_tm's Avatar
ima call some shops tomorrow but i might have to buy me one because my car is not drivable thanks guys
Modified by junior_tm at 9:49 PM 10/23/2008
Old Oct 23, 2008 | 09:26 PM
Default Re: (junior_tm)
buy one what? this is so incoherent
Old Oct 24, 2008 | 06:44 PM
junior_tm's Avatar
im going to buy a new used head anyways so
wut i meant was that i was going to buy a tester but im just going to get a new head
motormike40
Southeast (Sales)
Oct 30, 2010 08:25 PM
motormike40
Southeast (Sales)
Jul 24, 2010 08:05 AM
motormike40
Jul 15, 2010 03:39 PM
Samuels
Apr 16, 2006 06:59 PM
stoopid_monkey
May 17, 2005 11:19 AM
