Chipping an OBD2 ( OBDII ) ecu?
Old Aug 22, 2006 | 06:16 PM
FuNkDrSpOt's Avatar
Default Chipping an OBD2 ( OBDII ) ecu?
I've asked this question in some of the other forums with no success. I've tried to search and research as much as possible. I've even tried to go to http://www.pgmfi.org to try and learn some more, only to find out that I need to register and when I do, the registration e-mail doesn't get sent.
Anyways, I'm looking into chipping an OBD2 ecu. I've found one place, http://www.ericksracing.com/id98.html
, does the chipping using Techtom: http://www.technosquareinc.com/techtom.htm
hardware.
I know I'm talking to a very small crowd but for those of you who have chipped the OBD2:
1) I'm hearing issues of the ecu being re-written either by swapping the battery or by honda dealers....any truth to this?
2) That the chips aren't re-writeable
3) Are there any other issues that I might have to deal with?
Old Aug 22, 2006 | 09:54 PM
FuNkDrSpOt's Avatar
Default Re: Chipping an OBD2 ( OBDII ) ecu? (FuNkDrSpOt)
bump
Old Aug 23, 2006 | 12:32 AM
itekdu's Avatar
Default Re: Chipping an OBD2 (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">you're in a tough spot if you are determined to stay OBDII.
&lt;-- OBDII guy that finally saw the light and switched to OBDI ecu.</TD></TR></TABLE>
So, this is the kinda thread I have been looking for! whats the differences between the 2 ecu's, and what do you have to do to change over? is it easy?
cheers
Old Aug 23, 2006 | 04:05 AM
FuNkDrSpOt's Avatar
Default Re: Chipping an OBD2 (itekdu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itekdu &raquo;</TD></TR><TR><TD CLASS="quote">So, this is the kinda thread I have been looking for! whats the differences between the 2 ecu's, and what do you have to do to change over? is it easy?
cheers</TD></TR></TABLE>
No, this isn't that type of thread. Read the library from the pgmfi.org link in my first post.
This thread deals strictly with chipping the OBD2 ecu, people who have done it and complications/problems it caused.
Old Aug 23, 2006 | 11:18 AM
FuNkDrSpOt's Avatar
Default Re: Chipping an OBD2 (FuNkDrSpOt)
bump!
Old Aug 23, 2006 | 11:49 AM
EK k kay's Avatar
I don't think anyone has a chipped obd2 ecu on H-T. Keep going at pgmfi.org.
Old Aug 23, 2006 | 12:44 PM
Jaker's Avatar
It is possible to chip an OBD2 ECU. It involves de-soldering the 104 pin processor/memory and installing another one that has been re-programmed. The story about it getting re-written by changing the battery is false, as it would be the exact same as the OEM ECU, except with different data in the adjusted parameters on the programming.
Since it is necessary for the chip to be changed for the program to be changed, I don't see the dealer being able to re-write the program without changing the chip. It is however an elaborate process, and there are very few places that are set up to do it.
The chips can also be difficult to come by. These are not your run of the mill EPROMs, but actual prcessors with on-board memory.
All of this refers specifically to 96-00 Civics and 96-01 Integras. The newer stuff can be re-written by the dealer or anyone else with the correct equipment.
Old Aug 23, 2006 | 02:46 PM
FuNkDrSpOt's Avatar
Default Re: Chipping an OBD2 (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">It is possible to chip an OBD2 ECU. It involves de-soldering the 104 pin processor/memory and installing another one that has been re-programmed. The story about it getting re-written by changing the battery is false, as it would be the exact same as the OEM ECU, except with different data in the adjusted parameters on the programming.
All of this refers specifically to 96-00 Civics and 96-01 Integras. The newer stuff can be re-written by the dealer or anyone else with the correct equipment.</TD></TR></TABLE>
Cool. Thanks for the info Jaker. Do you know what program I would use to tune my car?
Old Aug 23, 2006 | 04:31 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
Cool. Thanks for the info Jaker. Do you know what program I would use to tune my car?</TD></TR></TABLE>
The only one I know of is the aformentioned "Techtom". I have not seen or heard of any "shareware" (Uberdata, Crome, etc...) for OBD2.
Old Aug 23, 2006 | 05:12 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">The only one I know of is the aformentioned "Techtom". I have not seen or heard of any "shareware" (Uberdata, Crome, etc...) for OBD2. </TD></TR></TABLE>
That sucks royal *****. You'd think that with millions on the table for OBD2 stuff that someone somewhere could simply crack the codes for it or AEM can make their EMS with an OBDII port.
Old Aug 23, 2006 | 05:58 PM
93turbo16's Avatar
You pretty much just have to get some blank procressors. You can actually pick them up on ebay if you look in the right places.
Old Aug 23, 2006 | 05:59 PM
nickromeo's Avatar
That sucks royal *****. You'd think that with millions on the table for OBD2 stuff that someone somewhere could simply crack the codes for it or AEM can make their EMS with an OBDII port.</TD></TR></TABLE>
dude if ur thinkning about aem u can use an obd1 AEM unit and just use a regular obd 1-obd2 conversion harness on ur obd2 engine harness connector into the aem and bam,
worky worky aem on an obd2 harness!
Old Aug 23, 2006 | 06:15 PM
spooncivic1's Avatar
Default Re: Chipping an OBD2 (nickromeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo &raquo;</TD></TR><TR><TD CLASS="quote">dude if ur thinkning about aem u can use an obd1 AEM unit and just use a regular obd 1-obd2 conversion harness on ur obd2 engine harness connector into the aem and bam,
worky worky aem on an obd2 harness!</TD></TR></TABLE>
or just get the aem that is made for his car.
Old Aug 23, 2006 | 06:35 PM
Jaker's Avatar
I think he has "smog" concerns, and the smog police not being able to "scan" the OBD2 ECU if its not OEM hardware.
Old Aug 23, 2006 | 07:43 PM
zerovandez's Avatar
I've been looking for a way too due to smog reasons.
You'd think it'll be like chipping an xbox!
Old Aug 23, 2006 | 08:01 PM
Schister66's Avatar
Man U FTW
why do people resist switching to OBD1....its not hard and its not expensive...
Old Aug 23, 2006 | 10:29 PM
FuNkDrSpOt's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">why do people resist switching to OBD1....its not hard and its not expensive...</TD></TR></TABLE>
Because it's illegal and won't be able to smog like that. If I can run the same ECU 24/7 then I'd like to do so.
Why do people on H-T get mad when someone wants actual answers and not just heresay and catchy phrases? It's just one of those unexplained questions in life
Old Aug 23, 2006 | 11:10 PM
FuNkDrSpOt's Avatar
Default Re: (moops vs moors)
Please stay on point or don't post at all, thank you. I'm well aware of everything you're already preaching about.
Opinions not needed, there are only 3 simple questions for those above.
jdmb1697ek
Apr 4, 2005 11:05 AM
wizzards581
Jun 28, 2002 03:35 PM
