chipped ecu and turbo
Old Nov 20, 2002 | 10:45 AM
1tyme's Avatar
Default chipped ecu and turbo
okay i know the chipped ecu is for na and has the timing is advanced, which is bad for fi applications. would it help for me to run my turbo more safely by retarding my distributer so i won't detonate?
Old Nov 20, 2002 | 12:55 PM
Speedworks801's Avatar
Default Re: chipped ecu and turbo (1tyme)
You can manually crank back timing on the distributor or the preferred option would be to purchase an MSD BTM or a Hondata, AEM of course.
Old Nov 20, 2002 | 12:56 PM
Default Re: chipped ecu and turbo (Speedworks801)
What's the application specifically and I could give you better advice.
Old Nov 20, 2002 | 02:10 PM
1tyme's Avatar
specifics is i'm running a b16a with a p28 chipped not sure wat program but vtec kicks in at about 5g, no governer, 9g revlimit, made for na so it's safe to assume that it's timing is advanced. turbo is not on yet thas y i'm asking questions first to be safe. but my set up is a t3 60/63, 450 DSM injectors, and i have a V-AFC that is currently hooked up so i'm goin to run the hack. hope this helps. thanks.
lilshady6796
Nov 30, 2009 07:23 PM
bustdgst
Oct 4, 2006 09:25 PM
LSpimpTEC
Aug 10, 2003 01:37 AM
CHK4TIX
Jul 29, 2003 04:55 PM
1tyme
Dec 4, 2002 10:39 AM
