Checklist of things needed when replacing rings??
Old Mar 9, 2004 | 10:56 AM
Pfieff's Avatar
Default Checklist of things needed when replacing rings??
I am going to be replacing the rings on my d16y7 this weekend and just wanted to make sure that I had everything I needed. I got a new HG, intake manifold gasket, oil pan gasket and the rings themselves. Anything else that I am missing?
Old Mar 9, 2004 | 11:28 AM
Bnjmn's Avatar
Default Re: Checklist of things needed when replacing rings?? (Pfieffdog)
patience. That is #1.
If your engine has a girdle you will need to take off the girdle to get at the rod bolts, so you'll need someone to hold up the crank for that.
You will also need a ring compressor and a torque wrench, but I assume that you have those.
You may want to put in new bearings while you are doing there and the crank will be off. Depends how many miles are on the engine.
Ben
Old Mar 9, 2004 | 11:32 AM
Pfieff's Avatar
I think the bearings should be fine as the engine only has 31k miles on it.
Old Mar 9, 2004 | 01:41 PM
Pfieff's Avatar
anyone else?
nico91civic
Apr 20, 2009 05:54 PM
ek9tl
Jun 18, 2007 04:18 PM
eg_gsr11
Mar 5, 2006 04:27 PM
sodacan33
Jun 10, 2004 07:10 AM
Type-Rare#1248
Mar 12, 2003 11:10 AM
