Check valve install
Old Sep 4, 2002 | 01:42 PM
speedymon's Avatar
Default Check valve install
Do you stick a silcone hose into the hole in the throttlebody. The hole where the map used to sit?
Old Sep 4, 2002 | 01:46 PM
brcivic411's Avatar
Default Re: Check valve install (speedymon)
ideally you want something to put the vacuum hose onto.. like a nipple of some sort. I had a metal plate that i could bolt onto the throttle body which i was also able to screw a brass nipple into that connected to the vacuum hose.
GameBoyeas
10
Jun 5, 2017 09:14 AM
93whiteg6
Dec 13, 2013 06:27 PM
accord8
Oct 8, 2012 09:04 PM
darrenwall
Aug 27, 2002 06:34 AM
TrueZen
Aug 10, 2002 06:13 PM
