Charge piping - what size?
Old Mar 25, 2002 | 12:09 PM
marklamond's Avatar
Default Charge piping - what size?
Hi,
I'm running a greddy 92-95 civic kit on a DOHC ZC @ 5psi and am about to get my charge piping tidyed up to make way for an intercooler/chargecooler. One question, what size should i use 50mm or 60mm?
As i'm running low boost (and don't intend to run anymore) would 60mm be too big and increase lag?
Cheers,
Old Mar 25, 2002 | 01:10 PM
qwkteg125's Avatar
Default Re: Charge piping - what size? (marklamond)
50mm will be fine.
Old Mar 25, 2002 | 01:12 PM
ATurboCivic2NV's Avatar
Default Re: Charge piping - what size? (qwkteg125)
do you have your ic yet? i know most have diffrent sizes on both sides. just FYI
Old Mar 25, 2002 | 01:14 PM
*Boostwerks*'s Avatar
50mm
Old Mar 25, 2002 | 03:20 PM
SiR Kid's Avatar
New User
Default Re: Charge piping - what size? (Bryson)
Make it the same size inner diameter and your throttle body for highest efficiency!
Old Mar 25, 2002 | 03:45 PM
marklamond's Avatar
Default Re: Charge piping - what size? (SiR Kid)
Thanks for the info folks!
50mm it is then (and it's a nice size to work with as well as the rex is tight for space). I'm going to get the intercooler/chargecooler custom made so i can get them to put whatever fittings i want on. I'll check my throttle body's I.D. also.
Cheers,
VyTaL
May 7, 2009 04:35 PM
Rodzknight
Feb 14, 2008 08:42 AM
HuskerHybrid
Jul 10, 2003 11:38 AM
i3oricua
Mar 31, 2003 05:28 PM
