changing turbo on my d16 will it work?
Old Oct 19, 2010 | 08:32 AM
b18master's Avatar
Default changing turbo on my d16 will it work?
I have an ebay 57/63 turbo and I'm changing it for a precision 6265 bb with .63 housing. I borrowed from a friend and want to know if it will work...
Old Oct 19, 2010 | 10:36 AM
shocker911's Avatar
Default Re: changing turbo on my d16 will it work?
it will work as long as you have the right flange on your turbo...and what is your DP flange as well.
Old Oct 19, 2010 | 10:43 AM
b18master's Avatar
some pics
Old Oct 19, 2010 | 12:14 PM
b18master's Avatar
here's a dyno chart of the last visit with the 57/63 ebay turbo @ 29psi...
Old Oct 19, 2010 | 12:47 PM
TheShodan's Avatar
Moderator
you may have a little difficulty with the compressor housing, as the one you have now is a T04S, instead of the T04E you had before. May require a bit of work to make it fit, but shouldn't be too bad depending upon manifold design. You'll need to change your outlet from the turbo to 2.5".
Old Oct 19, 2010 | 12:57 PM
b18master's Avatar
do you think it will have too much turbo lag???
Old Oct 19, 2010 | 02:42 PM
welfarepc's Avatar
that is up to you to decide...
my 6262 hits 20psi by 6100rpm
Old Oct 19, 2010 | 02:57 PM
Boosted-EH-804's Avatar
I was getting 15lbs from a 6262 .82a/r by ~5500 stg 4 PPorting head 3.6cam. I think it will be pretty laggy but will hit hard as hell once it finally does. What kind of head work do you have done? Cam?
Old Oct 19, 2010 | 09:00 PM
91jdmhatchback's Avatar
Idk about you but that thing will be lazy as hell on a d16. Looks like a p trim ex. wheel.
Your question about if it will work is odd. It will work fine as far as a turbocharger goes, but it won't and isn't a good match for a d16.
Old Oct 19, 2010 | 10:05 PM
TheShodan's Avatar
Moderator
This is true....This is true...
Old Oct 20, 2010 | 08:25 AM
b18master's Avatar
my head has a stage 3 port&polish and has a custom crower cam...
I just want to test it since i borrowed from a friend... then i will test a 6262 from another friend to see what works better on my engine...
tomorrow I'll go for a trip to the dyno and see how it works, and if we get some decent numbers we will go on friday the 1/4mile... : )
Old Oct 20, 2010 | 08:37 AM
b18master's Avatar
here are some more pics:
Old Oct 22, 2010 | 08:43 AM
b18master's Avatar
went last night to the dyno to test the 6265 turbo and it worked nice but didn't get the numbers i wanted...
made 497whp & 361wtq @ 29psi with some issues, the clutch gave up and we couldn't get it to at least 35psi...
the 6265 turbo worked well but i think it needs a .82 a/r housing and a new bigger camshaft like de bisi 3.6 and a new clutch kit...
so my question was answered the 6265 turbo really works on a d16... and works nice...lol
Old Jan 27, 2011 | 12:04 PM
0487erasmo's Avatar
Saludos, la 6265 q tines monta es ball bearing o journal?? Como es el spool de ESA Turbina en ese motor? Yo tengo um Palo Tambien montao, pero una 6262, .63 atras! Estaba pensando camber a 6265 pero queria saber como era el spool d la turbina.
Old Jan 27, 2011 | 01:05 PM
CanadianEF9's Avatar
no comprenday
Old Jan 28, 2011 | 01:57 PM
0487erasmo's Avatar
Originally Posted by CanadianEF9
no comprenday
This I wrote to B18master, that he understands the Spanish.
Old Jan 29, 2011 | 05:36 AM
joe111599's Avatar
What clutch are you running thats slipping?
Old Feb 12, 2011 | 04:02 AM
0487erasmo's Avatar
Any updated????
mikej94civex
Jan 6, 2010 04:35 PM
slowej1
Feb 1, 2008 05:32 PM
elpiar
Nov 13, 2006 07:55 PM
TacomanSI
Northwest (Sales)
May 24, 2006 05:57 AM
project dc2
Apr 23, 2003 04:37 PM
