changing parts and tuning
Old Jul 5, 2006 | 06:09 AM
igo4bmx's Avatar
Default changing parts and tuning
I understand changing exhaust housings or turbos or intercoolers can affect af, but does timing ever needed to be changed onces its been properly tuned?
Old Jul 5, 2006 | 06:20 AM
93turbo16's Avatar
Default Re: changing parts and tuning (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">I understand changing exhaust housings or turbos or intercoolers can affect af, but does timing ever needed to be changed onces its been properly tuned?
Both should be monitored/changed if they need it. With a smaller turbo you will be spooling up at lower RPMs. So you will be at higher boost levels at RPMs that you other turbo never hit. So they should atleast be monitored. I wouldn't just go tuning your a/f and assume the timing is where it needs to be. On the top end it should be about the same, but during spool is where I would have a look at be most concerned with knock.
Old Jul 5, 2006 | 06:29 AM
tony1's Avatar
Default Re: changing parts and tuning (93turbo16)
Going to a bigger housing you'll be fine, but a smaller housing will lower the knock limit and possibly cause detonation if it was tuned on the edge to begin with.
Old Jul 5, 2006 | 06:31 AM
igo4bmx's Avatar
Default Re: changing parts and tuning (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Going to a bigger housing you'll be fine, but a smaller housing will lower the knock limit and possibly cause detonation if it was tuned on the edge to begin with.</TD></TR></TABLE>
yeah my plans are to sell my sc50 and go with a gt28rs or maybe a gt2871r.
the real question is, when is neptune rtp coming out j/p I've already bugged James way too much
Old Jul 5, 2006 | 06:36 AM
93turbo16's Avatar
Very true.
turbo boost
Oct 24, 2007 10:44 AM
SOHC_MShue
Sep 17, 2006 09:47 PM
The Jacko
Jun 22, 2005 12:07 PM
platinum00
Dec 17, 2004 08:53 AM
rocket256
Jan 19, 2004 06:25 AM
