Ceramic Coating
Old Jul 28, 2005 | 04:53 PM
SOHC_MShue's Avatar
Default Ceramic Coating
Anybody ever used that spray on ceramic coating stuff? I tried using it on my dumptube and it didn't turn out so well. I put on 3 coats, let it dry completely, heated it at 250* for 30 minutes, let it cool, heated it at 400* for 30 minutes, let it cool, and then heated it at 550* for 30 minutes and then let it cool. After taking it out of the oven for the 3rd time the coating started flaking off when i picked it up. I followed the directions so what did i do wrong?
Old Jul 28, 2005 | 05:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ceramic Coating (SOHC_MShue)
probably didnt clean the surface well
Old Jul 28, 2005 | 06:11 PM
lucidvtec's Avatar
ya prep work is big time with ceramic coatings....ur better off going to a company like HPC...it will make a big difference they coat the inside and outside it's alot thicker..and you see way better results
Old Jul 28, 2005 | 06:25 PM
SOHC_MShue's Avatar
Default Re: Ceramic Coating (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">probably didnt clean the surface well</TD></TR></TABLE>
yea your right. I just degreased and used some sand paper...of coarse it already had paint on it that didn't work out because it wasn't high temp enough. You think i should remove all of the old paint first? Sorry i don't really know **** about painting .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">ya prep work is big time with ceramic coatings....ur better off going to a company like HPC...it will make a big difference they coat the inside and outside it's alot thicker..and you see way better results</TD></TR></TABLE>
i would, but the only reason i did this is to keep it from rusting. I couldn't find any decent regular paint that was high temp enough.
Old Jul 28, 2005 | 06:53 PM
wantboost's Avatar
Who is Mr Robot?
go find someone with a media blasting cabinet. work it over real good in the cabinet. take it out and wipe it down with acetone or brake cleaner.... wear gloves while doing all of this, you dont want the oils from your skin getting on the part. then hang it up from one end, clean it one more time then apply the coating
Old Jul 28, 2005 | 07:13 PM
SOHC_MShue's Avatar
i'll have to give it a try
Old Jul 28, 2005 | 07:14 PM
wantboost's Avatar
Who is Mr Robot?
yup, im just having mine done while its being built, mani, turbo (both sides) dp and dumptube
Boots
Dec 19, 2007 06:25 PM
Lethalb18c1
Dec 12, 2006 10:57 PM
Flux
Oct 25, 2006 08:11 PM
jDm_eDm
Aug 18, 2006 05:43 AM
xpsonic
Feb 25, 2005 04:50 PM
