CEL help needed. !!! Greddy turbo
Old Feb 10, 2002 | 11:07 PM
guyuenvy's Avatar
Default CEL help needed. !!! Greddy turbo
I have a 2001 gsr greddy turbo. Everything is stock. Ran the car so far for a year without problems. Two days aog te cel came on and it blinked a few times and then was constant. I pulled a code 72 and 73 misfire in cylinder 2 and 3. I reset the ecu but it pops right back up blinking then then constant. I changed out my spark plugs but the code is stil there after resetting ecu. What can be wrong?
Old Feb 11, 2002 | 09:09 AM
downpipe's Avatar
Default Re: CEL help needed. !!! Greddy turbo (guyuenvy)
check your compression. not to scare you, but mine started misfiring after my piston ring lands started cracking. or the blue box could be spazzing out...mine did that too...also greddy said that if you don't use their o-rings with the new injectors the seals might be compromised causing a misfire...but assuming it's been running well for a ywar it is probably not that.
good luck.
Old Feb 11, 2002 | 09:32 AM
sgT's Avatar
sgT
Default Re: CEL help needed. !!! Greddy turbo (downpipe)
you would notice a fuel leak though.... i hope
spoolin_si
Sep 22, 2005 02:03 PM
Boost Addict
Sep 3, 2004 08:04 PM
superturboprelude
10
Jan 29, 2004 07:18 PM
thejdmkid
Apr 19, 2002 10:51 PM
