Catch can stuffing?
Old Mar 12, 2004 | 12:15 PM
xci_ed6's Avatar
Default Catch can stuffing?
I ordered a cath can, one of my friends used steel wool in his, but that seems like it will break up.
What should I use that has little to no risk of seperating and being sucked into my engine?
Old Mar 12, 2004 | 12:22 PM
Mad Cow's Avatar
Default Re: Catch can stuffing? (krustindumm)
I was thinking about this yesterday, I think I'm going to find an inline filter that will go on the vacuum line to avoid the steel wool getting sucked up.
Old Mar 12, 2004 | 12:45 PM
xci_ed6's Avatar
Default Re: Catch can stuffing? (MadCow)
i thought of that, but less vacuum = less case ventilation.
Old Mar 12, 2004 | 01:04 PM
Daemione's Avatar
Use those stainless steel scrubber sponges, and make sure to have your PCV valve mounted after (or on) the catch can, not before it.
Old Mar 15, 2004 | 05:11 PM
Cyphear's Avatar
First to answer your question... I use those girly shower scrubber things, thats what bodykitsNW recommended.
do you guys feed your oil back into the block or what? I don't see how it could get sucked back into the engine with it venting to the atmosphere.
also, what is wrong with mounting the PCV valve before the catch can? Thats is how mine is hooked up now. The PCV valve IS the line running up in through the intake runners and up to the intake manifold, right?
Modified by Cyphear at 2:21 AM 3/16/2004
Old Mar 15, 2004 | 05:43 PM
XDEep's Avatar
Default Re: (Cyphear)
ive been using the scrubbers for months and they seem fine. mine is just run inline so it goes back to the pcv.
almostjdmeg
Mar 29, 2010 06:22 PM
eluder33
Mar 24, 2005 11:19 AM
D21X
Oct 12, 2003 11:15 PM
self_made
Oct 21, 2002 04:06 PM
outlaw racer
May 10, 2002 04:37 PM
