catch can
does anyone have preference to a good brand oil catch can?with so many options, im not sure what to get there are lots of brands greddy, nrg, weapon-r, Mfactory, 42 draft designs, not to even mention the hundreds of ebay knock off's
the 42 draft one looks pretty good. i need to get one very soon. please someone give a suggestion, if you have a link to a vendor that would be great to thanks.
If this is in ur price range GET IT. The best!!!
http://www.t1racedevelopment.com/en/...h-can-kit.html
ive got the endyne pcv kit on my car, it runs for 200$, but it comes with block off plugs to fill the holes in the back of the block for the stock pcv system which is entirely inefficient on stock honda, not to mention if your boosted, it comes with two new pcv fittings that are much bigger, and take the place of two oem plugs, so your getting a great pcv/catch can system for a great price http://www.theoldone.com/
cool good info ill look for that ...havent seen it on ebay. your bov looks just liek mine lol
Not sure, you really still need to be using a PCV on the "in" line for that, under high vac conditions it would suck incredibly hard on the motor, the whole design of the pcv valve is so that under high vac conditions the valve closes so that excessive amounts of oil are not litterally vacuumed out of the engine.
the endyn did my car fine up tp about 500whp.
wfter that, and as high as i am reving the car, it moves a good bit of oil.
recirc is the way to go unless you want to drain it every day.
all you have to do is change the oil a little more often.
there is an official catch can thread somewhere.
the t1 can may be overkill for you if you are single cam.
Mugen_DC2R
Oct 10, 2005 05:16 PM
Big Phat R
Oct 2, 2001 11:03 PM
