cartech fmu . what else
Old Oct 29, 2002 | 05:04 PM
redline201's Avatar
Default cartech fmu . what else
ok i am buying the maxrev kit (hondasaver)
i need some fuel and managment
i was thinking an fmu because its cheaper
i hear the cartech is more adjustable than the others
where can i find a cartech fmu and which one do i need
and do i need new injectors or an inline feul pump?
thanks
Old Oct 29, 2002 | 06:09 PM
sporkcrx's Avatar
Default Re: cartech fmu . what else (redline201)
I found mine on thepartstrader.com if you still dont have one in a month or so, i'll sell you mine for like 70 bucks or something...planning to switch to smc or safc hack in a lil. with cartechs you can adjust the base fuel pressure, and the rate of rise.
Old Oct 29, 2002 | 06:11 PM
sutrusu's Avatar
Default Re: cartech fmu . what else (spoon2)
well you really shouldn't base your fuel setup on something because it's cheap.
but if you want to run an FMU better make sure you have an inline fuel pump to give it enough pressure.
Old Oct 29, 2002 | 06:40 PM
redline201's Avatar
Default Re: cartech fmu . what else (sutrusu)
well not just because its cheap
i just hear the vafc hack and smc bog
the cartech seems to be the best option for me
and the hondata is to much $$
got any other ideas to run 7 or 8 psi on a b16a
Old Oct 30, 2002 | 08:24 AM
turbosol's Avatar
Check out the hostboard's FI integra board, they cater to JR kits and alot of them use the cartech. My friend picked up a used one from there.
Old Oct 30, 2002 | 01:45 PM
TeStUdO's Avatar
Default Re: cartech fmu . what else (turbosol)
id still use the smc and dsm 450's pretty cheap and better than running 90-100 fuel psi.
DXturbo
Jul 1, 2003 08:28 PM
TurbothisLS
Sep 22, 2002 07:22 AM
4gvtec
May 19, 2002 09:18 AM
FBP Ex-T
Feb 16, 2002 04:39 PM
ForcedAccord
Nov 22, 2001 09:22 PM
