Car Stutters after O2 Sim Install
Old Feb 10, 2003 | 06:36 AM
Bottoz's Avatar
Default Car Stutters after O2 Sim Install
Ok, I just instaleld the ECG O2 sim to get rid of my CEL 67. Now, under Low throttle (Less than %20) and Low RPM (2300 - 3300) my car starts to Stutter. Its very rhythmatic...like a slow pulse. If I give it more Throttle or get the RPM's above 3300 its smooth as normal. So, does the Secondary O2 affect fuel any? Could the O2 Sim box be 'off' in its calculations that its sending to the ECU?
The car is a 2000 Integra. It ran just fine before I Installed the O2 Simulator. Any Ideas?
Bottoz
[Modified by Bottoz, 4:34 AM 2/11/2003]
Old Feb 10, 2003 | 07:45 AM
nolimits's Avatar
Default Re: Car Stutters after O2 Sim Install (Bottoz)
The cpu doesn't make adjustments from the secondary o2 readings. If they are unsatisfactory, it will just throw the code (67). I'd check your wiring.
Old Feb 10, 2003 | 10:38 AM
Bottoz's Avatar
Default Re: Car Stutters after O2 Sim Install (nolimits)
Wiring is ok. I haven't thrown a 67 yet...so Im assuming all the wiring is ok.
Bottoz
Old Feb 10, 2003 | 12:01 PM
ineedhelp's Avatar
I'm having the exact same problem...still no answers. Got to the point where I got use to it. Anyone, with any suggestions??
Old Feb 12, 2003 | 08:52 AM
Bottoz's Avatar
Default Re: Car Stutters after O2 Sim Install (ineedhelp)
Ok, 2 people with same problem.....anyone?
Bottoz
igotthaspirit
Sep 17, 2006 01:45 PM
NoobEH2
Oct 5, 2005 06:33 AM
red_crx
Nov 26, 2004 04:38 AM
senpai
Jun 18, 2004 07:10 AM
BlkSIvic
Dec 18, 2002 05:10 AM
