Car not Starting! :( Please Help!
Old Apr 18, 2004 | 09:37 AM
RotiEatter's Avatar
Ditto
Default Car not Starting! :( Please Help!
Hey, I have a 1990 CRX DX with a B18A, converted to OBD1, using Hondata S200b. Setup is a DRAGIII kit, 450cc injectors, and a intank walbro fuel pump. I was at work about to leave and I went to start my car, before I start I always wait for the fuel pump to finish priming. So I turn the key and it doesn't start. I take the key out and try again, no fuel pump priming, no buzzing from the main relay. I am also getting a code, it's a constant code which is bad ecu. I get a ride home and try the ecu(p75 chipped for hondata) in my brothers project car 92 dx hatch. It starts but i cant see if it has a code since he has no dash, cluster or anything. I cant think of what can be causing this code. The only thing I can think of is the fuel pump wires came out of the butt connectors or something. What do you guys think? But would this cause a CEL?, and the main relay not to buzz like usual? Please help. Thanks
Old Apr 20, 2004 | 08:52 AM
RotiEatter's Avatar
Ditto
Default Re: Car not Starting! :( Please Help! (RotiEatter)
Tried a new main relay, didn't do anything.
Old Apr 20, 2004 | 09:16 AM
J337_UNIT's Avatar
sounds like a problem with the harness (one or more of the wires not connecting) possibly... did it work before?
Old Apr 20, 2004 | 11:46 AM
RotiEatter's Avatar
Ditto
Default Re: Car not Starting! :( Please Help! (J337_UNIT)
yes it did work for a day or 2.
stumy10
Nov 17, 2014 08:28 AM
Bolo_PR
Jul 26, 2012 07:47 PM
guedo148
Mar 20, 2010 05:41 PM
B18 CYA
15
Sep 16, 2006 12:04 PM
haroldthefly91crx
Aug 20, 2006 11:25 AM
