Car just gave up
Old Jan 12, 2004 | 07:10 PM
Rod.'s Avatar
Default Does this happen alot to you?
I was sitting at a light,all of sudden when it turned green, i tried to go and it just died. I didnt know what happened, never happened before. I turned the key and it started ,but would not keep idle. I would have to press the gas to keep the car on. If i didnt do that it would die. I just not put my timing back to normal, put some different spark plugs in(not new but ones I haevnt used in a while). Now it starts up go up in the rpms, idles for a few seconds then just drops to zero, and the car dies. What could be the problem??? I would like to fix it soon cause I close to getting it tuned with my hondata.
Setup
b18b1 '95
t3/t4 turbo
440cc rc injectors
safc hack (does not come on for some reason now just the buttons light up)
MSD ignition
walbro 255 pump
Old Jan 12, 2004 | 07:41 PM
BluntMan's Avatar
Default Re: Does this happen alot to you? (redturbocivic)
have you checked your fuel pressure?
Old Jan 12, 2004 | 08:04 PM
Johnyquest's Avatar
Default Re: Does this happen alot to you? (BluntMan)
Your AFC not coming on is your problem. Did you by any chance have a passenger kick ur ecu connections? happened to my friend not too long ago!
Old Jan 12, 2004 | 08:39 PM
92BlackSi's Avatar
Default Re: Does this happen alot to you? (Johnyquest)
timing belt check it
Old Jan 12, 2004 | 08:44 PM
B18C4-T's Avatar
Check your tps and make sure it hasn't moved out of adjustment.
Old Jan 13, 2004 | 03:57 AM
Rod.'s Avatar
Default Re: (B18C4-T)
before work bump
i unplugged the tps and plugged it back in...still doing the same thing
my safc has not been on in a week and had no problem till now
Old Jan 13, 2004 | 08:24 AM
Rod.'s Avatar
fuel pressure good...its at 45psi at idle
Old Jan 13, 2004 | 08:28 AM
boostin4drcivic's Avatar
my money is on the afc not being hooked up right anymore for some reason and now its biting u in the azz. check all of your connections on it to make sure nothing is loose.
Old Jan 13, 2004 | 08:46 AM
Del_Slowest's Avatar
Default Re: Does this happen alot to you? (boostin4drcivic)
im with everyone else, it's a connection. Did you crimp or solder....
Old Jan 13, 2004 | 09:32 AM
Rod.'s Avatar
Default Re: Does this happen alot to you? (Del_Slowest)
Crimp....it was running without it not hooked up. I didnt want to solder cause I was going to get it tuned this week with hondata. I guess i have to look the connection
Old Jan 13, 2004 | 10:39 AM
Your car was running 440cc injectors without the AFC being hooked up at all? How in the heck did you manage to idle those big *** injectors. I'm suprised it even started up at all. With that much fuel it should just blow out the spark and not even idle at all.
Old Jan 13, 2004 | 11:12 AM
InTeGrA B18b1's Avatar
not using an afc that pretty( i cant find the hammer) your injectors are probaly flooded with fuel.
Old Jan 13, 2004 | 04:43 PM
Rod.'s Avatar
It was hooked up but the screen wouldnt come on. I just now cleaned out my IACV and I jumped the harness to see if any codes popped out. It flashed once so that was oxygen sensor. So i cleaned that and it actually stayed on and idle. Now for the 440cc the idle stayed at only 500 rpms. So I am guessing the car will not be able to idle those now. I am going to put stock injectors in and see what happens. For the safc...checked connections and their good still doesnt come on
Old Jan 13, 2004 | 05:15 PM
twkdCD595's Avatar
check to make sure that the grounds are still in place and btw it would light if connected correctly unless your afc is fried or inoperative.
Old Jan 13, 2004 | 06:06 PM
MaxSterling's Avatar
Default Re: Does this happen alot to you? (twkdCD595)
CEL that is one solid light is bad ecu
Old Jan 13, 2004 | 06:12 PM
Code Blue's Avatar
Default Re: Does this happen alot to you? (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">CEL that is one solid light is bad ecu</TD></TR></TABLE>
could have fried the ecu with some bad connections... ouch
keep us updated for sure bro
Old Jan 14, 2004 | 04:43 AM
Rod.'s Avatar
Default Re: Does this happen alot to you? (Code Blue)
When I looked in my haynes book it told me the oxygen sensor. My car is obd-I if that helps. When I cleaned the carbon off the o2 sensor, it actually stayed on. It had a rough start but stayed on. I am thinking it is because of my 440 injectors now. I am going to change them out after work and hope everything works
Old Jan 14, 2004 | 05:22 AM
m R g S r's Avatar
My car actually idled dsm 450's. I thought I was having a problem with the SMC so I unplugged it and it idled, rough but it did.
Old Jan 14, 2004 | 06:39 AM
Rod.'s Avatar
Default Re: Does this happen alot to you? (m R g S r)
mine idles but only at 500rpms
Scott (T.O.A)
15
Jan 5, 2008 08:45 AM
import810
Sep 2, 2007 12:31 PM
reed857
May 18, 2005 10:04 AM
loserface
Nov 22, 2004 01:32 PM
