Car hesitating/studdering
Old Oct 19, 2003 | 06:24 PM
TurboJesse
Guest
Posts: n/a
Default Car hesitating/studdering
ever since i got my car tuned it has been studdering/hesitating. When i first start the car up and drive it, it drives and boosts smoothly the first ~10mins of driving...as the car warms up more it gets worse and worse. Low rpms are fine and the car idles fine. From ~4000-~5500rpms the car studders and hesitates excessively then clears up and goes into boost. It doesn't do this all the time and never when the car is cold...
Old Oct 19, 2003 | 06:55 PM
bottlefedb18c1's Avatar
it sould be too much fuel
correct me if i am wrong guys
Old Oct 19, 2003 | 09:35 PM
flymecourageous's Avatar
Default Re: Car hesitating/studdering (Mpir3)
could it be running hot and detonating.what kind of plugs are you running
Old Oct 20, 2003 | 07:32 AM
TurboJesse
Guest
Posts: n/a
Default Re: Car hesitating/studdering (flymecourageous)
ngk bcpr7s-11
Old Oct 20, 2003 | 08:07 AM
swlabhot's Avatar
What mgmt?
Old Oct 20, 2003 | 10:22 AM
TurboJesse
Guest
Posts: n/a
Default Re: Car hesitating/studdering (swlabhot)
hondata s100, was running great when the car was tuned.
Old Oct 20, 2003 | 05:48 PM
any chages made since the tunning?
anything at all?
Old Oct 20, 2003 | 05:56 PM
TurboJesse
Guest
Posts: n/a
Default Re: (bottlefedb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">any chages made since the tunning?
anything at all?</TD></TR></TABLE>
Just put my stock o2 sensor back in...i though it might have been that so i replaced it with a bosch one but it still does it.
Old Oct 20, 2003 | 07:09 PM
madman604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">ever since i got my car tuned it has been studdering/hesitating. When i first start the car up and drive it, it drives and boosts smoothly the first ~10mins of driving...as the car warms up more it gets worse and worse. Low rpms are fine and the car idles fine. From ~4000-~5500rpms the car studders and hesitates excessively then clears up and goes into boost. It doesn't do this all the time and never when the car is cold...</TD></TR></TABLE>
many people have this problem, including me. the warm startup issue. no fix so far.
Old Oct 21, 2003 | 11:25 AM
TurboJesse
Guest
Posts: n/a
Default Re: Car hesitating/studdering (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">
many people have this problem, including me. the warm startup issue. no fix so far.</TD></TR></TABLE>
I think thats differnt than what i have...after 15 or so mins of driving i pretty much can't boost anymore it hesitates so bad...its not just a little hesitation.
Old Oct 21, 2003 | 11:31 AM
DC2R714's Avatar
Aren't you using DSM injectors? If so that might be the issue too. I remember your car ran really well when it was tuned.
Old Oct 21, 2003 | 12:11 PM
TurboJesse
Guest
Posts: n/a
Default Re: Car hesitating/studdering (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Aren't you using DSM injectors? If so that might be the issue too. I remember your car ran really well when it was tuned.</TD></TR></TABLE>
yea...well originally my 550's were the cause of all the problems so we threw in some 450's as a last attempt to tune the car, it ran fine with them and we street tuned for about 2 hours the nite before the dyno with no problems...
Old Oct 21, 2003 | 01:49 PM
hawjdude's Avatar
i'm getting that problem with my car also. Nobody knows how to fix it. My car also hestitates at that rpm also.
Old Oct 21, 2003 | 06:55 PM
zip's Avatar
zip
Default Re: Car hesitating/studdering (hawjdude)
Need a valve adjustment, maybe?
Old Oct 21, 2003 | 07:00 PM
TurboJesse
Guest
Posts: n/a
Default Re: Car hesitating/studdering (zip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zip &raquo;</TD></TR><TR><TD CLASS="quote">Need a valve adjustment, maybe?</TD></TR></TABLE>
the car prolly does..but it was running perfect when i had it tuned, then the next time i drove it it does this...
Old Oct 22, 2003 | 01:44 PM
hawjdude's Avatar
Thats what one of my friends said.
Old Oct 22, 2003 | 02:14 PM
Mr. Softee's Avatar
that problem was always ignition related for me :dunno:
Old Oct 25, 2003 | 10:05 AM
CHILIBEANZ's Avatar
what do u mean ignition related? what did u do to correct it. i'm having the same problem with my rsx
Old Oct 25, 2003 | 10:35 AM
m R g S r's Avatar
Default Re: (p220)
I had the same problem, I was running stock plugs and the gap was huge!! Check the gap on the plugs, aern't the -11's gapped pretty large? Also, my ignition was retarded too much. Try checking those. BTW I have the smc 500 and dsm injectors.
Old Oct 25, 2003 | 12:45 PM
CHILIBEANZ's Avatar
i've got NGK 5671-7A gapped at .028 i had 5671-A8 and changed to a hotter plug because i thought that was the problem. the car will not stay at a constant rpm nor will it stay at a constant driving speed under non boost conditions.
any suggestions would benefit everyone having the same problems here. thanks
Old Oct 25, 2003 | 03:35 PM
Darin D.'s Avatar
Default Re: (p220)
sounds like an 02 sensor related problem. Unplug the o2 sensor and the car will run in open loop mode all the time like it does when the engine is cold.
Old Oct 25, 2003 | 04:48 PM
h22 civic's Avatar
dirty injectors maybe
Old Oct 25, 2003 | 05:47 PM
CHILIBEANZ's Avatar
i just checked both o2 sensors, my primary is brand new and both are cyling normally. i checked the injectors and they're fine, it's a brand new kit. keep em coming guys. thanks mike
Old Oct 25, 2003 | 07:29 PM
CHILIBEANZ's Avatar
have any of u guys ever heard of this: http://www.racingworks.com (the missing link)
Old Oct 25, 2003 | 09:33 PM
B18C GSR CIVIC's Avatar
Default Re: (p220)
My car did same thing. did nt do it be I got it tuned. Well it was tuned and running fine but missing up top so I wanted more boost and re tuned. After 3/5 hours dyno time. I t made more power with conservative settings but in ANY GEAR as long as i wasnt wot it would stutter like a bitch from 4800 to 5800. Its obvioulsly tuning and or ignition.
