Car Breaks Up
Old Jun 3, 2013 | 03:07 AM
WannaRun??'s Avatar
Default Car Breaks Up
hey everyone, Ive had my car tuned 3 times now and everytime this problem persists, when my car is at high enough rpms for vtec and I press the gas pedal all the way to the floor quickly without rolling into it the car will break up and then go, same as if I shift slowly between gears while doing a pull.
If I shift quickly there is no issue and if I roll into the throttle there is no issue.
Can anyone give me an idea of what it may be? I am not sure if its fuel/tune related or spark related. Thank you
Old Jun 3, 2013 | 04:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Car Breaks Up
Holy lack of pertinent details!
Setup?
CELs?
Etc.?
Old Jun 3, 2013 | 04:33 AM
D-Rob's Avatar
Could be TPS tip-in fueling being off a bit.
Have you consulted your tuner regarding the problem? I can't imagine not getting support for a problem like that.
Old Jun 3, 2013 | 04:39 AM
WannaRun??'s Avatar
Setup?
CELs?
Etc.?
No CEL's, No other issues. Car has stock ignition with ID2000s, twin full blown 340s, full blown fuel rail, fuel blown fpr, <---- the important stuff for the question at hand.
I have contacted my tuner, no response or help (Charm City Tuning), Im at work now but once I get home I will check out my TPS tip-in fueling and let you know the numbers. Thank you!
Old Jun 3, 2013 | 12:55 PM
yzracer323's Avatar
What kind of power are you making? Could be simple as plugs or a clogged fuel filter, or could be time for an upgraded ignition.
I would recommend Joe Simpson at Tempest racing for getting work done and tuning, they have always done a really good job on my cars. I heard CCT may be going under...
CimorelliCRX
Apr 7, 2022 12:16 PM
4tika4
Mar 12, 2009 08:00 PM
Andrew 825SM
Mar 10, 2004 06:53 PM
