car bogs after i let it sit for a week? confused.
#27
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearl »</TD></TR><TR><TD CLASS="quote">i just put on a FPR i had sitting in my basement, probably a year old, and it didn't change anything. could they both be bad? i think that would be a pretty rare occurance.
im telling u
stock ecu and injectors
this will tell u if the tune is bad now
i went through the same exact **** months ago
![](https://honda-tech.com/forums/images/smilies/emsad.gif)
im telling u
#28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">im telling u
i went through the same exact **** months ago</TD></TR></TABLE>
well i found another chip, but it didnt run right at all and i threw a CEL, so i just assumed it was of my other motor/setup.
im going to have my tuner send me another chip of my exact tune, if i cant find another ECU/injectors. its hard because i have a obd2a car with a obd2b motor
#29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearl »</TD></TR><TR><TD CLASS="quote">well i found another chip, but it didnt run right at all and i threw a CEL, so i just assumed it was of my other motor/setup.
oh snap for some reason i thought u had a 5th gen lol
i have obd1 injectors that were grinded to fit rc clips if that helps
#30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">oh snap for some reason i thought u had a 5th gen lol
i have obd1 injectors that were grinded to fit rc clips if that helps</TD></TR></TABLE>
nah man, you know i had a hatch
![](https://honda-tech.com/forums/images/smilies/emsmilep.gif)
#34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">try taking out the upstream o2 sensor and see if it revs up?
how do u know you don't have any junk in your injectors, did u take them out with the rail and check spray pattern?</TD></TR></TABLE>
i run a tuned obd1 ecu, the computer stays in closed loop and does not use any O2 sensor.
im not a injector guru, i have no idea what it looks like if my injectors are clogged.
![](http://images.honda-tech.com/set1/smile/emcrook.gif)
#35
well im leaning towards my injectors being bad. i decided to spray some carb cleaner into the tops of them and stuff. i have no idea if that is a bad idea or not, but whatever. car seemed to idle a little better and seemed to smooth it out just a little, but not enough to make it better.
still trying to find obd1 stock injectors and or 450's.
#36
Im having the same problem as you. It bogs/hesitates between 1000-3000 rpms just cruising, and also if i get on it. It just started happening so im not sure what it could be. Im goin to check my plugs tomorrow and try some fuel injector cleaner. Its pissing me off as well though. I just got it tuned 1000 miles ago too. So it cant be the tune (hopefully)
#38
james have you taken out the pump and saw what was going on in that tank? if i know you correctly you have no back seats and should be a 4 min job to get that pump out... you have me stumped though homie, ill keep thinking though. deff a fuel issue though. i dont however think your tune is fucked up. letting the car sit wouldnt do that i dont think. i have a spare ecu and stock injectors just use your conversion harness and my obd1 ecu and throw in the stock injectors to see how it runs. keep me posted.
#40
thanks dude. i had some injectors around and drew's ecu, but obd2 injectors dont work with obd1 clips
i tried a different chip on the ecu, same tune, and had th same issue.
ill take a look in the tank too. if you get a chance stop by with those goodies.
![](https://honda-tech.com/forums/images/smilies/emhammer.gif)
#41
ok i have obd1 injectors so they will work. i been working a lot because one of the other supervisors is in england but we need to chill again soon. maybe hit the beach in the crv
#46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IneedBoostInTheCoupe »</TD></TR><TR><TD CLASS="quote">wanna B20?!?.......lol...bymp for the dood</TD></TR></TABLE>
lol, you wanna deal with this problem?
#48
pearl, you can borrow my p2p (civic ex obd2b) ecu and stock 240cc injectors if you need to. i just need them back by the 19th of august to put back into my car for inspection time. let me know man
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
#50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearl »</TD></TR><TR><TD CLASS="quote">could my ecu be fried?</TD></TR></TABLE>
I think fried ecu's usually leave a solid CEL.
