Can this take a 100 shot?
Old Jan 25, 2006 | 08:22 AM
CBURKE's Avatar
Default Can this take a 100 shot?
Here is my setup, what I am building.
1991 Ls motor
Wisco pitson stock bore
Stock rods
ARP rod bolts
ARP head bolts (do the make mains for the Ls?)
ACL bearings
Eagle block guard
Head work will be
port matched head
1mm over sized valves
Crower springs
retainers
and cams (Stage one)
I may keep the stock intake manifold just port match it.
Tranny b16a cable
Fadanza fly wheel
Act clutch 2,600
Arp flywheel bolts.
Dsm injector 440cc
AFC to control them
255 fuel pump
I am wanting to use a 100 shot easy. And if needed, would like to step up to more.
Kinda want to know where the major flaws are in this set up. I know about the stock rods maybe being a problem, but any thing elas you guys see? thank for any help.
Here is a few pics of the car.......
1.
2.
3.
4.
5.
Modified by CBURKE at 9:56 AM 1/25/2006
Old Jan 25, 2006 | 08:28 AM
cuin9sec
Guest
Posts: n/a
i dont see why it wouldnt. dont run a single fogger...go direct port so each cylinder get an even amount of nitrous.
Old Jan 25, 2006 | 08:36 AM
wisjdmhonda's Avatar
Default Re: Can this take a 100 shot? (CBURKE)
id say get some aftermarket rods, only $300. MIght as well since the motor is apart.
Old Jan 25, 2006 | 08:39 AM
CBURKE's Avatar
That is what I was thinking too. The car is really never going to see the street, only for brake in. Will I have to notch the block if I get the rods?
Old Jan 25, 2006 | 08:41 AM
RTE117's Avatar
I'm sure it could, but I would go ahead and aquire some aftermarket rods. Then you can spray even more.
Old Jan 25, 2006 | 09:40 AM
CBURKE's Avatar
Ok, but other then the rods everything looks good?
Old Jan 25, 2006 | 10:13 AM
Quad-Damage's Avatar
Default Re: (CBURKE)
why not go with like a real way to tune it not a VFAC, something like crome or uberdata they are not much and if you know people who can tune it, it's well worth the money, Crome has nitrous control as well
Old Jan 25, 2006 | 11:30 AM
CBURKE's Avatar
oh, ok......
I was not even thinking about that. I just thought it would be the way to go. thanks
H-allmotorda9
Mar 13, 2010 05:08 AM
akura404
Mar 3, 2006 02:12 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
S13 slide
Sep 25, 2002 02:14 PM
H22CIVIC
Dec 5, 2001 04:00 PM
