Can someone interpret this compressor map for me?
Old May 16, 2006 | 08:46 AM
UNforgivABLE's Avatar
Default Can someone interpret this compressor map for me?
Im just wondering the max HP this turbo could make on a b16 and max efficiency.
Turbo is garrett gt32 52 cold side 78 hot side
I wouldnt mind a link on how to understand these either
Old May 16, 2006 | 11:25 AM
Mag00n's Avatar
Default Re: Can someone interpret this compressor map for me? (.Keyser Soze)
i would say ~350whp on a b16 but im not very good at reading those charts
Old May 16, 2006 | 01:13 PM
.God.'s Avatar
Default Re: Can someone interpret this compressor map for me? (Macan00n)
looks to be most efficient from 200-350 hp
That smallest shape is an efficiency island, the entire area inside that shape is where it is most efficient.
100lb/m = ~ 100hp worth of air...(very rough estimate)
Pressure ratio = atmopsheric pressure + boost pressure / atmo pressure
compressor maps are only used to make estimations there are a ton of other variables.
correct me if i'm wrong on any of this
Old May 16, 2006 | 06:04 PM
whiteef8's Avatar
Default Re: Can someone interpret this compressor map for me? (..Lloyd Braun..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..Lloyd Braun.. &raquo;</TD></TR><TR><TD CLASS="quote">looks to be most efficient from 200-350 hp
correct me if i'm wrong on any of this</TD></TR></TABLE>
sounds about right, from what i understand. im not too sure about the 100lb/min=100hp thing, but most people go from around there i guess, depending...i would also say around 250-300, give or take
mattsnooz
Feb 22, 2008 05:41 PM
shadyGs-R
May 28, 2006 12:54 PM
b18bEKcoupe
Apr 12, 2005 07:27 PM
Quick 200k Mile Motor
Nov 10, 2002 12:18 PM
