can I hit 300hp with an LS with this setup?
Old Nov 1, 2003 | 05:41 AM
Mr.DC2TurBo's Avatar
Default can I hit 300hp with an LS with this setup?
Looking to hit hi 280-300 with mild internals on an LS. Is this possible or am I dreaming...
setup:
Rev hard turbo kit with t3/t4b
hondata s200
3" exhaust
440 cc injectors
v-afc boost controller (boosting at 15 lbs)
Crower pistons and rods at 9:2 ratio
Old Nov 1, 2003 | 05:48 AM
tommyten's Avatar
Default Re: can I hit 300hp with an LS with this setup? (Mr.DC2TurBo)
very possible
Old Nov 1, 2003 | 05:50 AM
Default Re: can I hit 300hp with an LS with this setup? (hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling &raquo;</TD></TR><TR><TD CLASS="quote">very possible</TD></TR></TABLE>
what else do I need to make it a sure thing?
Old Nov 1, 2003 | 05:53 AM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
what else do I need to make it a sure thing?</TD></TR></TABLE>
A dyno, and a reputable shop. Get that **** tuned.
Old Nov 1, 2003 | 05:54 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
get bigger injectors. Yep you can get 300whp, I would get as different turbo as well. I'll be making over 300 next year. Now im making close to 270 on a cold day who knows .
Old Nov 1, 2003 | 06:04 AM
Default Re: can I hit 300hp with an LS with this setup? (HybridcivicLS-T)
hey hybrid, did you change your LS head at all? what kind of setup is yours. I love those numbers of yours with just 11psi.
Old Nov 1, 2003 | 06:13 AM
espanol's Avatar
with the right set-up 300 whp on a ls is pocket change.
Old Nov 1, 2003 | 06:26 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">hey hybrid, did you change your LS head at all? what kind of setup is yours. I love those numbers of yours with just 11psi.</TD></TR></TABLE>
Nope everything is stock. completly I keep the revs were they belong, my moto: the more you rev the more you tear. I just put the right things together and made great horsepower. I just looked at other people set-ups and seen what they were making and i knew what i would get. I looked at an old post i made a while back, before i was tuned people asked me what i would make i said 260ish.I was right on the money when it came down to it. Jus tput good products together and have a great tuner, and a have a healthy enigine you'll have fun.
Old Nov 1, 2003 | 07:08 AM
TurboJesse
Guest
Posts: n/a
yes, you could have done it on stock internals fine..
Old Nov 1, 2003 | 07:37 AM
Ri5e's Avatar
Default Re: can I hit 300hp with an LS with this setup? (Mpir3)
12-14 Lbs should do it with some good tuning. It varies depending on the condition of the motor ...
Old Nov 1, 2003 | 01:08 PM
RXM's Avatar
RXM
Get it tuned by Jack, and you'll end up walkin home
Old Nov 1, 2003 | 01:10 PM
brianSilverTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">v-afc boost controller (boosting at 15 lbs)
Typo? Did you mean the AVC-R? cause afc won't control your boost as far as I know.
Old Nov 1, 2003 | 03:29 PM
mskibbz-T's Avatar
Default Re: can I hit 300hp with an LS with this setup? (brianSilverTeg)
Hmm, I didn't know Crower made pistons... Are they decent?
Old Nov 1, 2003 | 03:53 PM
JM Performance's Avatar
Default Re: can I hit 300hp with an LS with this setup? (mskibbz-T)
what turbine on the turbo? i have a t04b/t3 w/ a stage 2 .48a/r housing and hit only 230 at 10psi. to hit 300 your gunna need at least the stage 3 .63 housing.
otherwise, yeah, it shouldn't be that hard.
Old Nov 1, 2003 | 04:03 PM
mskibbz-T's Avatar
Default Re: can I hit 300hp with an LS with this setup? (00SilverLS)
I hit 260+ at 9.7 PSI on my stock LS with a T3/T04E 60 trim .63 AR, with very conservative timing... Tuner thought we could have gone for 275+ easily if he had a knock sensor, he didn't feel comfortable tuning timing much more aggressive without a knock sensor
fishieman
Sep 27, 2008 02:24 PM
SilverWarrior
Mar 31, 2008 11:39 PM
jayzonmyfeet
Sep 17, 2006 06:28 PM
jdmwhiteboy
Feb 7, 2006 11:58 AM
silentdaredevil2
Jan 19, 2006 08:33 PM
