cams for boost
Old Sep 4, 2004 | 08:37 PM
sqad_7's Avatar
Default cams for boost
I've been looking around the site and i've seen that most people use GSR cams on boosted motors. Are there any other cams that would be ideal for stock GSR head thats boosted
Old Sep 4, 2004 | 08:44 PM
lanojp1's Avatar
ITR cams can be used
Old Sep 4, 2004 | 08:46 PM
sqad_7's Avatar
Default Re: (lanojp1)
i had talked to a friend who had some for sale but he said that the GSR cams are better than type R's when it comes to boost
Old Sep 4, 2004 | 09:27 PM
hybrid901's Avatar
Default Re: (sqad_7)
It will depend on how much boost and mainly how high you are reving your motor. I found that on my setup the itrs made more peak power above 8500 but the gsr were way better under the curve.
Old Sep 4, 2004 | 09:57 PM
BoostedEG6's Avatar
probably the best cam for you would be to change out the intake cam only put a ITR (integra type R) the exhaust cams are the same for the GSR and Type R but the intake has alittle bit more lift and is very good with a basic turbo set up. GSR's are also a good cam but with the type of person I am I like to have top end power and not alot in the low RPM's as this just causes you to lose traction right away.
Old Sep 5, 2004 | 04:22 PM
22psicrx's Avatar
Default Re: cams for boost (sqad_7)
crower has a cam for stock motors
Old Sep 5, 2004 | 04:31 PM
Chip's Avatar
Default Re: cams for boost (22psicrx)
I am going to do some experimenting. I have a set of Skunk2 Stage 2 cams from an old N/A build, and I'm in the process of putting together an 84MM LS/VTEC with a GT35R. I have an ITR head, some GSR cams, and the skunk2 cams. Once I get the motor done I plan to dyno test all 3 cams, get some real results
Old Sep 6, 2004 | 04:44 PM
sqad_7's Avatar
Default Re: cams for boost (Chip)
thing is i would like to keep the stock rev limiter I'm not looking to go past 8000 but i want the most power out of my set up. And i'm not looking to build the head right now to go past 8000
Wilka
Dec 9, 2012 01:41 PM
jksmith
Nov 3, 2008 05:52 PM
Pr0j3ctxH@tchx90
Apr 20, 2007 03:38 AM
JsNA99si
Mar 12, 2004 10:08 PM
fast[R]
May 28, 2002 02:35 PM
