cam cap bolts snap
Old Apr 26, 2008 | 03:56 PM
avotegra's Avatar
Default cam cap bolts snap
i just snap one of my cam cap bolts the 12mm one...and its the middle exhaust one..........is it ok to run with just one bolts off,... and if i try to fix it.......how to i fix it........do i drill a reverse tread screw inside untill it screw out.............
Old Apr 26, 2008 | 05:11 PM
avotegra's Avatar
Default Re: cam cap bolts snap (avotegra)
help
Old Apr 26, 2008 | 05:21 PM
philafelman's Avatar
im assuming you overtightened it (not cross threaded). get the snapped part out....with no head on the remainder of the bolt, should be relatively easy coming out....reverse bolt remover should do it, i wouldnt leave it out...if you screw up the cap...it will get a lot more expensive. if you cant get it out on your own, take the head to a machine shop, they shouldnt have a problem getting it out.
but on a much more ghetto note (NOT RECOMMENDED)...i have ran with one stripped bolt before.
Old Apr 26, 2008 | 05:22 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avotegra &raquo;</TD></TR><TR><TD CLASS="quote">i just snap one of my cam cap bolts the 12mm one...and its the middle exhaust one..........is it ok to run with just one bolts off,... and if i try to fix it.......how to i fix it........do i drill a reverse tread screw inside untill it screw out.............</TD></TR></TABLE>
No, it is not ok to run with one missing.
How the heck did you snap it in the first place?
invisible
58
Apr 11, 2007 08:54 AM
Mugen112
Sep 14, 2006 11:06 AM
DC2_ALL MOTA
Aug 28, 2006 02:50 PM
HamiltonRex
Feb 28, 2006 01:57 AM
HondaGuy02
Oct 20, 2004 08:05 PM
