call me crazy but....
Old Mar 27, 2004 | 05:27 PM
DaveF's Avatar
Default call me crazy but....
im shooting for 700 HP on race gas...street car.
here is my question.
WILL 3 inch intercooler piping be a problem???
some "specs"
wet sump oil system from z10 motorsports
built block
fully done up "race head"
extrude honed,intake mani/75mm throttle body
ceramic ball bearing t66
clutch
ems
Old Mar 27, 2004 | 05:34 PM
ITSTOCK's Avatar
Default Re: call me crazy but.... (Dturbocivic)
Damn baller! What kind of turbo mani is that? also what size bore are you running
Old Mar 27, 2004 | 05:38 PM
DaveF's Avatar
Default Re: call me crazy but.... (ITSTOCK)
that is a rev hard manifold(which i sold)
we are going to be building our own manifolds when the collectors get here (cody )
the block is an ls block, golden eagle sleeves,9.0:1 comp, 81mm, crower rods, gsr block girdle.
Old Mar 27, 2004 | 05:45 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
How is that seal on the Z10 unit? I was looking at getting that one. I've been told the Moroso one has leak issues, but haven't heard any bad press on the Z10 yet.
Nice setup. Especially the turbo. Bling Bling
Old Mar 27, 2004 | 05:48 PM
DaveF's Avatar
Default Re: call me crazy but.... (Nid Styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nid Styles &raquo;</TD></TR><TR><TD CLASS="quote">
Nice setup. Especially the turbo. Bling Bling</TD></TR></TABLE>
honestly i dont know, i havent used it yet.
im sure with a proper installation, you will have no leak issue's with either oil pan.
i have a friend with a moroso pan, which has no leak issue's
here is his car. ---&gt; https://honda-tech.com/gara...=1249
Old Mar 27, 2004 | 05:53 PM
Nid Styles's Avatar
That cold air for his turbo is pretty crazy. Never seen anything like that. Creative.
Old Mar 27, 2004 | 06:06 PM
h22 civic's Avatar
all sounds good but the turbo t66 mite be a wee bit to small for 700
Old Mar 27, 2004 | 06:09 PM
DaveF's Avatar
Default Re: call me crazy but.... (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">all sounds good but the turbo t66 mite be a wee bit to small for 700</TD></TR></TABLE>
im thinkin the same thing... lol...its a good start though.
Old Mar 27, 2004 | 06:14 PM
mildly.interesting's Avatar
nice pics....*****
Old Mar 27, 2004 | 06:24 PM
DaveF's Avatar
Default Re: (mildly interesting)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mildly interesting &raquo;</TD></TR><TR><TD CLASS="quote">nice pics....***** </TD></TR></TABLE>
SO what is everyone's take on the 3 inch intercooler piping.
i just picked up these bad *** aluminum v-band connectors from Z10 and i want to put them to good use.
Old Mar 27, 2004 | 06:26 PM
Nid Styles's Avatar
Default Re: (Dturbocivic)
i just picked up these bad *** aluminum v-band connectors from Z10 and i want to put them to good use. </TD></TR></TABLE>
3 inch should be good, but what kind of intercooler are you going to be using?
Old Mar 27, 2004 | 06:51 PM
h22 civic's Avatar
Default Re: (Nid Styles)
ive seen 3" make little over 700 should be fine ,as far as intercooler good question but by the looks of the rest of the set up im sure its all good under the hood
Old Mar 27, 2004 | 06:59 PM
DaveF's Avatar
im goin with the "big" precision intercooler. "750hp"
i am than going to cut off the 2.5 inch outlets..make the hole 3 inch in the end tank, and weld a portion of my v-band to the intercooler. my whole setup will only have 4 "hose" conections, all v band... 1 coming out of the turbo, 1 goin into the intercooler, 1 out of the intercooler, and than 1 at the throttle body.
Old Mar 27, 2004 | 07:27 PM
showtymers619's Avatar
* B A N N E D *
maybe a vtec sticker! j/p
m R g S r's Avatar
How much boost are you planning on running? So you decided not to sell your whole setup? Good choice
Old Mar 27, 2004 | 07:59 PM
*Boostwerks*'s Avatar
Pretty much using everything that wouldn't sell eh?
Sounds good...hehe..
Old Mar 27, 2004 | 09:56 PM
Blackack26's Avatar
Default Re: call me crazy but.... (Bryson)
very impressive!
Old Mar 27, 2004 | 11:53 PM
Charles B.'s Avatar
Default Re: call me crazy but.... (Blackack26)
excuse my noobness and sorry for going a little ot, but what are the advanatges of having the fpr before the fuel rail?
edit: also, doesn't i/c piping need a little bit of play to handle vibrations? would using v-band clamps for the i/c piping cause them to be more prone to cracking?
Old Mar 28, 2004 | 12:50 AM
rjardy's Avatar
Default Re: call me crazy but.... (SuperDuperEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperDuperEG &raquo;</TD></TR><TR><TD CLASS="quote">excuse my noobness and sorry for going a little ot, but what are the advanatges of having the fpr before the fuel rail?
edit: also, doesn't i/c piping need a little bit of play to handle vibrations? would using v-band clamps for the i/c piping cause them to be more prone to cracking?</TD></TR></TABLE>
Its just that the regulator other than stick allows for more flexibility in fuel regulation.
Rob
Old Mar 28, 2004 | 02:48 AM
the-anti-crack's Avatar
ok....crazy but!
that sounds like a lot of fun. i hope to see vids in the near future.
Old Mar 28, 2004 | 03:54 AM
KamikazeSol's Avatar
The idea of V-bands sounds good, but as mentioned already you need someplay in the system for vibration. That is why all kits use some connectors to help with the play that will be involved in the moving engine. V-bands will probably only give way to problems in the future.
Old Mar 28, 2004 | 05:03 AM
tony1's Avatar
Default Re: call me crazy but.... (KamikazeSol)
I agree, you better have some damn solid mounts if you use solid ic piping. As for the size...we ran 3" on kenny's car...
Old Mar 28, 2004 | 06:44 AM
Del's Avatar
Del
Default Re: call me crazy but.... (tony1)
hmmm....... 750 hp street car...... nothing like a 120 mph burnout, hope you spent some of that loot on chasis stuff so you can have a little traction
Old Mar 28, 2004 | 07:32 AM
boosted_dc2's Avatar
Default Re: call me crazy but.... (Del)
i dont know what this guy uses for sizing...
https://honda-tech.com/zerothread?id=645704
but he makes 712 hp, i dont know and im not an expert but im asking, would 3 inch piping make that much of a diference than a 2.5". im sure there are some physics involved like air flow and volume. i guess the drawback would be it would take longer to spool????? probably not that noticable, but at the same token how noticable would 3 inch be to 2.5 inch???
Landon
Old Mar 28, 2004 | 08:00 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I agree, you better have some damn solid mounts if you use solid ic piping. As for the size...we ran 3" on kenny's car... </TD></TR></TABLE>
we got the solid mounts under control,
thanks for all the reply's im going to have this running within a month or so. ill be sure to post up the pics of the porject in progress..
as of right now...
the car is a 97 hx coupe(black)
everything interior wise is pretty much stripped, engine bay is empty, we are fabbing up solid motor mounts and a traction bar today.
no carpet, no sound deadning, no heater,no ac, dash is in but stripped(going to put my autometer guages in there)
i will have a pretty much full interior, when the car is complete, just want to get it running first.
car is "rolling" on 15 inch flat black konig traffik's ...bfg drag radials up front..and kuhmos on the back.
