Calculating Injector Pulse Width
Old Jan 15, 2004 | 10:32 AM
  #26
incogNitto's Avatar
Default Re: Calculating Injector Pulse Width (Arturbo)
****...i better bring extra looseleaf
Hey Art you're going to be at the Huntington Beach seminar this weekend? Gonna be a few HT celebs there Am I invited to the after party guys?
Old Feb 6, 2004 | 03:54 AM
  #27
Hoosier Daddy's Avatar
Default Re: Calculating Injector Pulse Width (incogNitto)
Great info, even after an all nighter I understood it for the most part. Gonna read it again later on today
See you guys at the CT seminar
Old Sep 13, 2004 | 11:01 PM
  #28
94cxhybrid-T's Avatar
New User
Default Re: Calculating Injector Pulse Width (EFIGUY)
back from the dead, but i wondered what is meant when he refers to 100% VE?
throttle percentage? load?
Old Sep 14, 2004 | 06:16 AM
  #29
IN VTEC's Avatar
Default Re: Calculating Injector Pulse Width (94cxhybrid-T)
VE is an acronym for volumetric efficiency. It's measured as a percentage of the total volume of a cylinder bore. It's easier to understand in this example:
If you have an engine with a displacement of 1.8L, and for a single revolution, it's able to fill the entire 1.8L with air, then it has 100% VE.
You would normally consider just a single cylinder, but since the engine is a combination of multiple single cylinders, you kind of have to make assumptions that the cylinders are homogeneous....even if they are not precisely so.
VE changes throughout the rpm band and load.
The caveat is that engines are almost never 100% volumetrically efficient, unless they're supercharged (a generic term for forced induction) or have strong manifold resonance at a narrow range of rpm.
Supercharging (and IN/EX manifold resoance effects to a certain degree) can increase VE beyond 100%.
What is load you ask?
Load and throttle percentage are proportionally related. More throttle = more load on the motor. More load = more air that is available to the cylinders for ingestion. Load is also synonymous with manifold pressure. More manifold pressure = more air that is available to the cylinders. It all fits together nicely.
Old Jan 2, 2007 | 09:24 PM
  #30
drumminforev's Avatar
Default Re: Calculating Injector Pulse Width (IN VTEC)
crazy how this sick thread just ended. more good info?
Old Jul 2, 2007 | 06:16 PM
  #31
B18EG6's Avatar
Default Re: Calculating Injector Pulse Width (drumminforev)
If anyone can give some input to my injectors not getting any pulses I would be greatly appreciative
Pictures + oscilloscope screenshots found in this thread
https://honda-tech.com/zerothre...15074
Old Apr 25, 2010 | 08:26 PM
  #32
nutzsrt4's Avatar
good write up
1slowcrx
Aug 8, 2011 03:55 PM
JayJay2912
Jun 16, 2010 08:24 AM
PirateMcFred
Apr 9, 2010 10:58 PM
Spade
Feb 8, 2006 06:05 PM
safe driver
Oct 1, 2003 09:36 PM
