A/C with DRAG log mani?
Old May 26, 2009 | 12:12 PM
matt94z's Avatar
Default A/C with DRAG log mani?
I am piecing together a turbo kit for my 2000 EM1 Si and Im wondering if I'll be able to keep my A/C. I have a cast DRAG manifold. I plan on ditching the power steering, but would really like to keep the A/C for when it rains and the windshield get all fogged up... that sucks!
Thanks!
Old May 26, 2009 | 03:52 PM
TheShodan's Avatar
Moderator
Default Re: A/C with DRAG log mani?
as long as you have a 5 bolt exhaust housing on your turbocharger, shouldn't be a problem
Old May 26, 2009 | 10:00 PM
project dc2's Avatar
5-bolt turbine housing ( precision, Turbonetics, garrett and OEM garrett only !!)
Ebay/ Borg warner/ China-made turbos will not fit because they do not follow the " standard" guidelines of turbo placement ( ford style) 5 bolt turbine housings that drag used to design their manifold around. If you use these other turbos, the setup will very likely not bolt up to your motor setup.
and call us for a 2.5 ac compatible downpipe If you call drag turbo, they too will direct you to our shop for downpipe fabrication
Old May 26, 2009 | 10:04 PM
matt94z's Avatar
I got a garrett 50 trim.
boostincoupe
Jul 26, 2005 03:52 PM
Bictorious
Feb 17, 2004 11:54 PM
Chrome Pipes
Feb 9, 2004 03:50 PM
91cvcsi
Jun 4, 2002 12:33 AM
93LSivic
Jan 22, 2002 05:40 PM
