built motor wont start..
Old Feb 23, 2007 | 06:03 PM
thomas@LPS's Avatar
Default built motor wont start..
well ive had the s300 in my car for almost a year and have came across a problem. the car has been sitting for a couple of months while i built a new motor. the issue is that the ecu light will be green for a few seconds then go red after the fuel pump primes just wondering what this means??? i sure its something electrical but not sure what? the motor is 75.5mm wisecos, eagles, calico coated bearings fully balanced and blueprinted. port and polished head, crower springs and retainers t3/t04e 50 trim. thanks for your help.
Old Feb 23, 2007 | 06:05 PM
Snafubmx234's Avatar
Default Re: built motor wont start.. (civic_ex_95)
Okay, you've told us that the ECU lights up. Does the car turn over? If so, do you smell fuel? Is your mechanical timing correct? Do you have a map loaded on to your car? I prefer to use free engine management so I'm not down with how S300 works. Pardon me for my ignorance.
Old Feb 23, 2007 | 06:40 PM
thomas@LPS's Avatar
the motor turns over. has fuel and spark. but there is definately something wrong with the ecu and/or wiring. the light is supposed to be green all the time now it is red.
Old Feb 23, 2007 | 06:52 PM
IntegraTypeR's Avatar
Default Re: (civic_ex_95)
re-burn the map and double check your senosrs are hooked up!
Old Feb 23, 2007 | 07:47 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (IntegraTypeR)
dont hate on s300. I run s300 on my ls vtec turbo built and it runs like a champ. Get it dyno tuned bro and dont whine. You get what you pay for.
Old Feb 23, 2007 | 09:03 PM
Default Re: (PnoyLSV-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyLSV-T &raquo;</TD></TR><TR><TD CLASS="quote">dont hate on s300. I run s300 on my ls vtec turbo built and it runs like a champ. Get it dyno tuned bro and dont whine. You get what you pay for. </TD></TR></TABLE>
Did I, or anyone for that matter, hate on S300? I have had zero problems with Crome (the free version), so don't get all butt hurt that my free system runs just fine.
To the OP - You've verified that the motor has fuel/spark? The map on your ECU can't just "go away," something has to have changed. Verify that you indeed have both spark/fuel, make sure your mechanical timing is set, and make sure all of your sensors are hooked up properly. If your fuel/spark are there when they need to be, the motor should start up.
Old Feb 24, 2007 | 06:23 AM
HiProfile's Avatar
Ever try dyno'ing a motor that won't start? BTW, the fuel map can just 'go away' due to electro-static discharge, among other things. Its rare and only time it happened to me was one time I was handling a chip, and guess what - it would start, hardly idle, then die. Reburned (same map & chip), and it worked perfect.
OP: did it run with all those engine mods before? Its possible for gas to go bad after a while, so maybe top off the tank with new 93octane, then do the normal fuel system checks/maintenance.
Old Feb 24, 2007 | 06:29 AM
qfast817's Avatar
Default Re: (HiProfile)
i would check all your grounds and sand them down. also check the ignitor ground.
Old Feb 24, 2007 | 09:54 AM
thomas@LPS's Avatar
i can get my old map off of the ecu and load a map to the ecu. another thing that has changed is that im on the newer version of hondatat sofware. but i have no feedback from any sensors on the car. the only thing that has changed on the car is the motor itself.
Sithscott1
Mar 18, 2016 01:22 PM
B_Swapped93
Jun 20, 2014 02:32 PM
bass man
Mar 14, 2013 08:16 PM
DC2_ALL MOTA
Sep 1, 2006 07:55 AM
Civicman86
Nov 23, 2005 02:48 PM
