built lsvtec stroker
Old Aug 11, 2011 | 03:23 AM
EGcivic_95's Avatar
Default built lsvtec stroker
okay i am building a lsvtec and its going to be boosted but the question is, can i or would it be a good idea to stroke it? if so what mm crank would be best to get? it will be a fully built motor plus a bore will be done as well
Old Aug 11, 2011 | 04:13 AM
EGcivic_95's Avatar
Default Re: built lsvtec stroker
sorry on the info....84 mm bore and 95 mm crank from eagle...
Old Aug 11, 2011 | 04:19 AM
kyden's Avatar
i wouldn't bother with stroking it, especially with an eagle crank.
Old Aug 11, 2011 | 04:23 AM
EGcivic_95's Avatar
ok why not wih a eagle crank? i herd they are better then the crawler cranks and why not stroke it? info on it?
Old Aug 11, 2011 | 04:48 AM
TheShodan's Avatar
Moderator
I suppose its what you plan to do with this car, as you need appropriate rods to match with that crank. OEM does just fine for over 900whp+ if drag racing. For circuit, its possible but not necessary.
Please elaborate as to what a "crawler" crank is.
Old Aug 11, 2011 | 05:02 AM
EGcivic_95's Avatar
Brian Crawler stroker kits...i herd the crank is garbage because they spin bearings quite fast and continuous, this is what i herd from people and i was going to get the kit from golden eagle, are the rods from a kit like this any good, id like to see some where around 7-800 hp if possible using the rods from the kit...
VTC#2
May 23, 2013 02:28 PM
sour97
Sep 30, 2007 05:05 PM
cherryhatch00
Jan 15, 2007 02:57 PM
mec. pedri
Feb 25, 2006 05:26 PM
cyrix12
Aug 14, 2005 07:02 PM
