Built B18C1 engine pics
Old Mar 15, 2004 | 03:06 PM
jmagner's Avatar
Default Built B18C1 engine pics
Here are the newest pictures of our EG Civic turbo buildup. This is a 94 B18C1 going in a 92 Civic CX. Specs are on the website. http://www.turboeg.tk
Right now we have a new T-25 turbo but it isn't capable of our HP goals so we are looking to upgrade to a t3/t04e, possibly an SC61.
Old Mar 15, 2004 | 03:27 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Built B18C1 engine pics (jmagner)
nice, whats the set up gonna be?
Old Mar 15, 2004 | 03:28 PM
jmagner's Avatar
Default Re: Built B18C1 engine pics (preacherboy)
Engine:
B18C1
JE 9.0:1 c/r Pistons
Eagle H-Beam Rods /w ARP Rod Bolts
Golden Eagle Blockguard
Polished Crankshaft
JDM Crank Pulley (alternator only)
Cometic Turbo Head Gasket
ARP Head Studs
Garrett T25 Turbocharger .49/.89 A/R
Greddy Type-S BOV
Tial 38mm Wastegate
SSAutochrome Turbo Manifold
Skunk2 Intake Manifold
Hondata Heatsheild Gasket
Vortech Fuel Rail /w Optimizer
Walbro 255lph Fuel Pump
AEM Engine Managment System
Transmission:
Y80 5 SPD
ACT Streetlite Flywheel (12.5 lbs.)
ACT Stage 3 Clutch (Street Disc & Extreme Pressure Plate)
Suspension:
Tokico Blue Gas Shocks
Skunk2 Springs
GSR Strut Bar
Interior:
Civic Si Guage Cluster
Modified by jmagner at 8:03 PM 3/15/2004
Old Mar 15, 2004 | 03:43 PM
boosted_dc2's Avatar
how much power you expecting to put down??? those are stock sleves right??
Landon
Old Mar 15, 2004 | 03:54 PM
jmagner's Avatar
Default Re: Built B18C1 engine pics (boosted_dc2)
325-350whp, and yes stock sleeves...
Old Mar 15, 2004 | 03:57 PM
VNTEC's Avatar
B A N N E D
Wow man.... For a sec it looked sleeved! Man just to think the only thing u raelly need to add is rods pistons and a block guard... you got a VERY nice set up!
Old Mar 15, 2004 | 04:00 PM
jmagner's Avatar
Default Re: Built B18C1 engine pics (VNTEC)
Thanks!
We decided that the money was well spent going into an EMS. Our HP goals are within the capability of stock sleeves and good tuning should keep it reliable.
Old Mar 15, 2004 | 04:05 PM
Honda Hick's Avatar
I would give the head a good cleaning and clean out those exhaust ports while it's off. Looks good though.
Old Mar 15, 2004 | 04:10 PM
jmagner's Avatar
Default Re: Built B18C1 engine pics (Honda Hick)
Any recommendations on what to clean it thoroughly with? It's mostly oxidation and thats a pain in the *** to clean up. We are probably going to run it as is for now, and take care of the entire head when it comes off later for work. In the future we are upgrading the valvetrain, port/polish, and 3 angle valve job. When it's rebuilt for that, it will be a better time to really scrape it clean.
Old Mar 15, 2004 | 04:30 PM
rocket256's Avatar
That is coming along real good. Are you standard bore?(3.189)
Old Mar 15, 2004 | 04:33 PM
jmagner's Avatar
Default Re: Built B18C1 engine pics (rocket256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">That is coming along real good. Are you standard bore?(3.189)</TD></TR></TABLE>
Yes, 81mm
Old Mar 15, 2004 | 04:45 PM
typeRSXS's Avatar
i heard block guard is unreliable? you guys kno any more on that?
Old Mar 15, 2004 | 04:55 PM
jmagner's Avatar
Default Re: (shupaGSR)
I've heard that some blockguards have caused overheating problems. I've heard the GE guard flows better than most and doesn't have problems. All of this is word of mouth so I can't back up anything yet. Soon enough I'll be able to let you know how the GE block guard performs. As far as other reliability issues, I don't see how a properly installed guard could create any.
Old Mar 15, 2004 | 04:57 PM
typeRSXS's Avatar
ooo ok, nice setup
Old Mar 15, 2004 | 07:02 PM
jmagner's Avatar
bump
Old Mar 15, 2004 | 08:01 PM
RyanEJ8's Avatar
Nice build.
I did almost the same build-up on my D16Y8, the GE blockguard hasn't caused me any overheating problems.
Old Mar 15, 2004 | 09:17 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">325-350whp, and yes stock sleeves...</TD></TR></TABLE>
Good luck reaching that with the T-25.
I'm glad you realize that you will need a larger turbo. A 50 trim with .48ar turbine is right up your ally.
black92eg6
Mar 24, 2009 11:41 AM
black92eg6
Northern California (Sales)
Feb 18, 2009 06:42 PM
qtcivicturbo
Aug 9, 2007 09:53 AM
black_ek
Jul 23, 2007 08:05 AM
_SHIFT
Dec 28, 2005 04:37 PM
