Building Up Engine For Future Supercharger...
Old May 25, 2006 | 08:10 PM
H23_Del Sol's Avatar
Default Building Up Engine For Future Supercharger...
I wanted to know what you guys think I would need to do to my motor is get it ready for a Jackson Racing Supercharger... I currently am addressing all head work cams, gears, retainers, valves and valve springs... and if they is any other head component i didn't name that you feel I should also upgrade...... please give me some other feedback on buliding up my motor like block and tranny...???
Thanks
Old May 25, 2006 | 08:26 PM
Tad's Avatar
Tad
how much power are you going for?
I wouldn't worry too much considering most ppl dont make it over 300 with jrsc's anyways,
so just concentrate on stuff that'll make power as opposed to bulletproofing the block(not that that cant hurt mind u)
Old May 25, 2006 | 09:12 PM
Only 300.... there isn't a way to build more whp???
Old May 25, 2006 | 09:17 PM
Tad's Avatar
Tad
sure there is,
sky's the limit if you've got enough dough
you doing this to ur h23 ?
Old May 25, 2006 | 10:13 PM
yes to the H23..... what did you have in mind..... for "sky's the limit"
Old May 25, 2006 | 11:08 PM
Tad's Avatar
Tad
well anytime I think about a high hp blown honda,
endyns sohc comes to mind..
made over 400 on a nonvtec sohc..
its blower was modded all to hell, with like carbon impellar blades, fully custom intake/intercooler setup, lots of custom stuff.
at the very least just make sure you get lht's intercooler kit, and run a medium ammount of compression.. maybe somewherea round 10-10.5
3" exhaust, proper header, do ur homework on ur cams, good portwork on your head, and as much tuning as you can get
heh, more than I can afford, so i'll live vicariously through you
Old May 26, 2006 | 09:42 PM
Well... currently I have 193 too the wheels that is without LSD and flywheel for the tranny... no internals done to the head no block work done a crappy header and no supercharger.... I should be well over 300 don't you think....
Old May 27, 2006 | 03:06 AM
non-VTEC's Avatar
Default Re: (H23_Del Sol)
upgrade the pistons and rods.....thats all you can to to make the bottom end stronger.
you want more power.......run more boost and have it tuned properly. i don't know what the power limits of a JRSC on a H23 but if you run 10-12psi you should be able to get over 300hp with the right tuning.
Old May 27, 2006 | 05:36 AM
So that's basically what I should do to make the bottom end stronger
Old May 27, 2006 | 10:16 PM
I was wondering... If did all that head work... cams, gear retainers springs and valves would my engine be able to handle all these new parts and the power that will be made from adding these parts... or will I have to upgrade pistons and build the block also???
Old May 27, 2006 | 11:29 PM
Tad's Avatar
Tad
yeah I wouldn't run over 11psi on a non-modded jrsc
go read the jrsc thread man, it's enormous but theres lots of good info in there.
Old May 28, 2006 | 06:11 AM
I'll do that... but I was talkin about the head work... If I did that would the engine be able to hold all the new upgrades...
BigRex88
Feb 13, 2012 03:23 AM
InvaderTrax
May 4, 2010 05:14 AM
BoiTypeR
Feb 22, 2007 09:35 AM
black06lude
May 18, 2006 06:57 AM
