buddy of mine needs some help..could this lead to apossible problem?
Old Feb 8, 2005 | 09:27 PM
a1320addict's Avatar
Default buddy of mine needs some help..could this lead to apossible problem?
buddy of mine got a turbo....with an internal wastegate..the internal wastegate support bracket seems to have one of its holding bolts that went through a part of the copmressor housing...nothing serious..the housing has been taken off to inspect for debris and none was found..just a small hole in the compressor housing it self...will this pose any problems in the future? im thinking its the same thing as having a step-silicone coupler setup....just create a tiny bit of turbulence..but nothing severe..looking for some opinions
Old Feb 9, 2005 | 06:55 AM
beepy's Avatar
Default Re: buddy of mine needs some help..could this lead to apossible problem? (yehiknowrite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">..the internal wastegate support bracket seems to have one of its holding bolts that went through a part of the copmressor housing...</TD></TR></TABLE>
I don't understand. Did you take it out or did it break? Did you remove the wastegate actuator bracket? Are all the bolts still holding the compressor together?
I forsee problems. A bit of flex will ruin your compressor wheel. A hole is always bad.
Old Feb 9, 2005 | 08:41 AM
Default Re: buddy of mine needs some help..could this lead to apossible problem? (beepy)
one of the bolts on the support bracket went through a part of the compressor housing...about 40% through...it is slightly visible when looking into the compressor outlet...he called up the r & d and they said it wont be a problem but would be happy to replace it...so im assuming if they are gonna be happy to replace it...but are saying its not a problem...then its not going to be really?
5thgencivic
Welding / Fabrication
Nov 4, 2005 12:45 PM
White98LS
Aug 6, 2005 10:09 PM
a1320addict
Feb 10, 2005 09:11 PM
Superdragr45
Sep 26, 2004 10:57 PM
mamaboy
Jun 23, 2004 02:45 PM
