Brake boost hose - Tee fitting size?
Old Jul 3, 2003 | 08:08 PM
MachAF's Avatar
Default Brake booster hose - Tee fitting size?
I'm wanting to use the brake booster hose for my vacuum source. Anyone know what size tee I should get?
Thanks
Old Jul 3, 2003 | 09:42 PM
disguy409's Avatar
i need to know the same thing... bump
Old Jul 4, 2003 | 12:10 AM
Sprockets's Avatar
Default Re: Brake booster hose - Tee fitting size? (MachAF)
If you go to Pep Boys they sell the plastic T that you cut to the size you need, but the opening still wasn't big enough. Home Depot or Lowes, sell 3/8" barb fittings with a 1/4" NPT male. Buy 2 of these and a 1/4" barb to 1/4" NPT and a 1/4" female T and some teflon tape. I'm sure if you check online somewhere they might make a T with 2 - 3/8" barbs and a 1/4" barb, but I didn't look. Anyway, 3/8 isn't a super tight fit, but it's snug enough. As far as I know, there is no size inbetween 3/8 and 1/2, so I went with 3/8. Use hose clamps, not zip ties.
Old Jul 4, 2003 | 09:23 AM
MachAF's Avatar
Default Re: Brake booster hose - Tee fitting size? (The Dude)
thx man!
Old Jul 4, 2003 | 10:45 AM
Sprockets's Avatar
No problem. You might want to check to see if they sell 1/8" NPT to 3/8" barb fittings. The inside diameter will be the same, but the T will be smaller since it's 1/8" NPT.
KeithDigital
Nov 23, 2008 06:02 PM
geezer_187
May 8, 2006 04:18 PM
underpressure02
Mar 20, 2006 07:06 PM
mark45840
Mar 24, 2005 07:36 PM
Type Goch
May 30, 2003 11:16 AM
