Bov soft to hard adjustments?
What type of bov do you have? there is an adjustment screw on top which will dictate the stiffness of the bov. Hard and soft mean how much pressure it takes for the valve to open and vent the air... Soft= least amount
Modified by Sulli at 3:56 AM 4/30/2004
hMm, I wonder also... I gotta Greddy TypeS BOV> New... Maybe I should just start from stock settings, and adjust from there..
Trial and Error pretty much. Run your car, and if you notice its releasing to much pressure, then tighten it up a little. -
Slowly to the right amount needed.
i dunno, i was messin with mine yesterday, and it does the same thing screwed all the way out as it does with only 1 thread showing(screwd almost all the way in)
Just hand tighten it till you can't tighten it anymore..then tighten it a SMALL amount with a wrench...Guys unless your are running crazy boost levels a tuned bov isn't going to affect your motor performance.
