bov chatter, or is it compressor surge?
Over the past weekend I replaced my intercooler with a larger one along with the piping.
I used to have a 3'' 90 degree elbow coming off my turbo with the filter on the end. Well the way the new piping is ran i cant run my intake like that anymore so I have the filter just clamped onto the turbo. the problem is that my bov now sounds like it chatters when it goes off.
I know it's not because of the piping or intercooler because it did this before (thats why I installed the intake)..
Why would my bov chatter when I have no filter or just the filter attached to the turbo with no piping between?
It did this with my old bov (saab) and my new one. Is it something I should worrry about? Look into?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo »</TD></TR><TR><TD CLASS="quote">sounds like bov is either adjusted improperly or bad/leaking vac source</TD></TR></TABLE>
So why would it do it only when I have no intake? It's fine when I have a intake hooked up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid »</TD></TR><TR><TD CLASS="quote">what bov?
is it too tight?
vacuum source not strong enough?
i know i have comp surge with the shitty max rev bov im using.
megan racing bov
It did this with my bosch bov too, so I know it's not the bov. I even adjusted it with no avail.
Vacuum source comes strait from the pcv valve so I know it's good.
is it too tight?
</TD></TR></TABLE>megan racing bov
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">I've used the Max-Rev BOV with no problems. Are you sure its adjusted properly. </TD></TR></TABLE>
YES.
I had this same problem with a different non-adjustable bov.
Works fine with 10'' intake pre turbo, makes chatter sound when I remove that piping and run a filter only or even with no filter.
This bov I'm using now, is adjusted correctly because it chattered when I first put it on, I adjusted it and the chatter went away. It has ran fine since then. That is until I remove that section of piping.
it's not the bov, nor is it the vacuum source. Thats why I'm baffled, both of those items have been addressed.
YES.
buttsneeze
Mar 17, 2005 11:07 PM
civbeater90
Sep 2, 2002 12:39 AM
