Bottom end check list, am I missing anything?
Old Nov 17, 2003 | 04:29 AM
EFb18b's Avatar
Default Bottom end check list, am I missing anything?
ok here's what I got so far but I would like to know if I am missing anything before I start putting it back together:
Sleeved block
84mm cp 9.0:1 pistons w/rings and pins
crower 4340 rods
re-balanced gsr crank
acl bear kit w/ lube and thrust washers
oil pan gasket
2 bungs for my oil pan
new oil pump
main seals
now am I missing anything? I don't care how mundane it is. I want to make sure I don't have to tear the whole thing back down because I missed the dumbest thing. This is going to be a straight street class race motor and i'm hoping for mid-low 10's at about 28-30psi
Thanks to anybody that can help
EDIT: added stuff to the list of what I have
Modified by Redlineracer at 4:41 PM 11/17/2003
Old Nov 17, 2003 | 04:55 AM
Double121's Avatar
Default Re: Bottom end check list, am I missing anything? (Redlineracer)
New head bolts for sure...
Old Nov 17, 2003 | 05:01 AM
30psi Teg's Avatar
deffinitly ARP Head Studs and Main Studs if you are looking for that kind of power.
Also you might as well get new main seals (new oil pump should have one). I would just get all new gaskets and O-rings if you havnt already. Everything else looks good though
Old Nov 17, 2003 | 06:20 AM
EFb18b's Avatar
Default Re: Bottom end check list, am I missing anything? (30psi Teg)
Yeah I was definitely going to get main and head studs not too mention new seals. I just forgot to put that on my list and that is the reason why I wanted to make sure before I started. Thanks alot guys
So other than that I should be good to go?
Old Nov 17, 2003 | 06:32 AM
30psi Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlineracer &raquo;</TD></TR><TR><TD CLASS="quote"> So other than that I should be good to go?</TD></TR></TABLE>
Old Nov 17, 2003 | 09:14 AM
99B16Si's Avatar
thrust washers, and oil pick up tube gasket.
thats all i can think of
Old Nov 17, 2003 | 12:42 PM
EFb18b's Avatar
Default Re: (99B16Si)
got that stuff
thanks for reminding me
Da9 Ripples
Jul 18, 2013 08:56 AM
laziebun
Nov 4, 2007 04:57 PM
turbogsr18
Dec 15, 2006 05:29 PM
doublejz
29
Aug 3, 2005 04:44 AM
hatchy
Apr 5, 2002 04:01 PM
