bottom end build up?
Old Dec 4, 2001 | 03:57 PM
JDB's Avatar
JDB
Default bottom end build up?
I have a 2000 civic si and putting a votech supercharger on. I would like to know if anyone knows what would be the best rods,pistons,rings,and crank if needed. I'm looking to get at least 300 whp out of it. Any ideas are helpful.
Old Dec 4, 2001 | 06:36 PM
liam821's Avatar
25 Year Member
Default Re: bottom end build up? (JDB)
ditch the charger and get a turbo..much better!! A stock b16a at 10-12psi will make around 280hp @ the wheels..or 319hp @ the crank...100% stock.
vortec dyno charts show around 270-280hp @ the wheels at high rpm on stock b16a..which is around 300-320hp @ the crank.
liam
[Modified by liam821, 7:37 PM 12/4/2001]
Old Dec 4, 2001 | 07:17 PM
DIRep972's Avatar
Smarter than you
Default Re: bottom end build up? (liam821)
HAHAHAHA I love honda-tech.. youll probably want to get apex 3mm seals and a street port if u r gonna run alot of boost.
jk man, eagle rods w/ endyn pistons is a great set up for the money.. but If you are serious about making alot of power anywhere over 300 you may want to consider a turbo..
[Modified by DIRep972, 4:19 AM 12/5/2001]
Old Dec 4, 2001 | 07:22 PM
Tomakit's Avatar
Default Re: bottom end build up? (DIRep972)
ha, even though this is the "Forced Induction" forum, its really the "you need a turbo for your honda" forum, haha.
anyway, you seriously dont want the vortech, its a peaky system mated to a peaky motor...no fun.
proper sized turbo would be much more fun.
for the build you'd want eagle rods and endyn/wiseco/je pistons.
Tom
Old Dec 4, 2001 | 08:35 PM
adam's Avatar
Default Re: bottom end build up? (Tomakit)
agreed
Old Dec 4, 2001 | 09:07 PM
liam821's Avatar
25 Year Member
agree also
liam
Old Dec 5, 2001 | 05:53 AM
ArizonaTurbo's Avatar
I fyo are looking at getting a good set of rods & pistons for a decent price go with:
Eagle Rods
SRP,JE, or Wiseco Pistons
Old Dec 5, 2001 | 05:59 AM
BoM's Avatar
BoM
Default Re: bottom end build up? (APEXSER)
importparts.com
has rods for 365!
pistons either JE or Endyn their around 400 too
AllMotorITR
Dec 17, 2001 07:53 AM
FAST4DR
Dec 15, 2001 07:40 AM
Dec 8, 2001 05:46 PM
