Bosch 40 intank fuel pump?
Old Nov 21, 2010 | 06:17 AM
jspeedy's Avatar
Default Bosch 40 intank fuel pump?
I've seen a lot of people using the bosch 44 inline pump but no one seems to be using the 40 intank. My walbro is either going, or is just not up to the task, so I'm looking at the bosch 40 which flows 300 lph. I know people are going to say, us both the walbro intank and the bosch 44 inline, but I really don't want to deal with the noise of the inline pump. My neighbor has a bosch inline and I can hear it from across the street.
below is the specs and write up I found for the bosch 40.
Bosch 0 580 254 040 In Tank Fuel Pump
Bosch 040 fuel pumps are universal style in tank fuel pump replacements recommended for vehicles exceeding OE specifications. The Bosch 0-580-254-040 fuel pump is one of the only in tank fuel pump that can be compared with the Walbro 255LPH High Pressure series fuel pumps for use in vehicles with up to 700 horsepower.
Bosch 040 Fuel Pump Specs:
Bosch Part Number: 0580254040
Minimum Current: 12 Volts
Operating Pressure: 94 PSI (6.5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In Tank
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 930 Grams (2.05 Pounds)
Fuel Pump Connections:
Inlet: Open Base
Outlet: M10 x 1.0
Electrical: Positive M6 / Negative M5
$199.99
Old Jan 3, 2011 | 09:43 AM
B00st3d-dc2's Avatar
Default Re: Bosch 40 intank fuel pump?
Same question here, anyone?
Old Jan 3, 2011 | 04:07 PM
runsfromdacops's Avatar
i have that same in tank bosh but i also have a 044 inline.works much better then the walbro/044 combo that most use.
i dont think youll make any where near the clamed 700hp on the 040 alone
jdmcivic2fast
Dec 12, 2010 07:24 AM
prelude994e
Sep 13, 2004 11:23 AM
digitalhav0c
Feb 5, 2003 12:41 PM
