Boosting 7psi....supposed to only hit like 4.
Old Dec 21, 2001 | 08:34 PM
JM Performance's Avatar
Default Boosting 7psi....supposed to only hit like 4.
Ok, I have my wastegate hooked up to my compressor. So w/ the .4 bar spring that is supposed to be in there I should only hit like 4 psi after the IC. However I hit .5bar...about 7psi.
My guess is that I was sent the wrong wastegate spring (although it does say ".4bar spring - DONE" on the box). However could anything else be causeing the problem? Could a restrictive exhaust or restrictive wastegate loop (the damned FMAX closed loop that goes right into the top of the downpipe) be causeing this?
I'm gunna have FMAX send me a new spring, just to be sure, but is there anything else I should look for?
Old Dec 21, 2001 | 09:23 PM
DeeJay's Avatar
New User
Default Re: Boosting 7psi....supposed to only hit like 4. (00SilverLS)
If you open up the Tial you can tell by the color of the spring. Green is .6bar and brownish red is .4bar. I had Scott make my DP open loop cause I thought the slip joint was shady.
Old Dec 21, 2001 | 09:46 PM
Default Re: Boosting 7psi....supposed to only hit like 4. (DeeJay)
Yeah, I fucked up, I should have gotten the open loop downpipe. I'm gunna do closed loop, but they're system sucks; I'm gunna be changing it anyway. Definitly do closed loop though. Having the car be completely quiet all throughout boost is soooo nice!
Yeah, my slip joint is leaking. I have some super hight temp gasket maker that I'm gunna fix it with though.
Also, how do I check the spring. Just undo all those bolts around the wg?
[Modified by 00SilverLS, 1:46 AM 12/22/2001]
Old Dec 21, 2001 | 11:11 PM
Rob03Pro5's Avatar
.4 bar = 5.8 psi.. you're not creeping much. just a tad over 1 psi.
Old Dec 22, 2001 | 12:14 AM
PureTeg420's Avatar
Default Re: Boosting 7psi....supposed to only hit like 4. (Rob92SC)
but with the pressure loss from the IC it's more like 2 or 3psi....i say open it up and see what spring you've got in there...
Old Dec 22, 2001 | 09:23 AM
GruvyTune's Avatar
New User
Don't trust Scott, you probably have the green spring in there. He didn't have any .4bar springs last I asked him. I had to buy mine. Cost 30bux.
young geezer
Aug 3, 2009 12:54 PM
ATgrills.com
Apr 9, 2005 07:04 AM
RNPoo7
Apr 6, 2005 04:20 PM
FlatTire
Apr 29, 2004 01:47 PM
speedymon
Sep 10, 2002 08:09 PM
