boosted high compression
Old Jan 10, 2013 | 06:36 AM
  #26
stowne78's Avatar
Default Re: boosted high compression
Originally Posted by Ash J. Williams
you COULD run O2 sensors with avgas, but it is not cheap, and you would have to clean the sensors often. it also isn't good for you, at all.
I made the mistake of buying a Bosch wideband sensor. The MTX-L computer/gauge is great, the sensor is pathetic. Anyway is brakleen fine to use for those sensors to clean them up? Maybe if I clean it every once in awhile it will last longer.
Old Jan 10, 2013 | 06:39 AM
  #27
wantboost's Avatar
Who is Mr Robot?
Avgas is the best stuff on the planet, next to sex, Italian sports cars, and marrying Sasha Grey.
Of course you can't just drive onto the tarmac and fill your car up at every airport you come across. I think 100LL by my dads house is like 4.85 a gallon I think? We know the airport owner (he lets us do speed pulls down the tarmac for tuning) if you can bring a 55 gallon drum or some sort of container and fill it up.... if you know someone that works at a small airfield
Old Jan 10, 2013 | 09:30 AM
  #28
evilpenguinking's Avatar
Originally Posted by th3pwn3r
You're talking like you're Donald Trump but are running stock sleeves for some reason. Can you give us the reason as to why?
just testing the boundaries...no one got anywhere not taking chances. I know its stupid with stock sleeves, just wanting to try it out...
Old Jan 10, 2013 | 09:58 AM
  #29
yea im running the ngk powerdex with ngk sensor
Old Jan 10, 2013 | 10:09 AM
  #30
dcmatt's Avatar
if your worried about inconsistency with pump E85 then try C85. if your really ballin then go with FTW purple. A good build for you to check out would be muckman's high compression build.
Old Jan 10, 2013 | 11:37 AM
  #31
Muckman's Avatar
Moderator in Chief
Yeah!
Old Jan 10, 2013 | 11:40 AM
  #32
wantboost's Avatar
Who is Mr Robot?
With high compression, stock sleeves, and boost... one good detonation event will shatter a sleeve
Old Jan 10, 2013 | 03:36 PM
  #33
AFAccord's Avatar
You wanted to shoot some videos of high boost pulls in the Accord?
Old Jan 11, 2013 | 07:06 AM
  #34
yungmulacrx's Avatar
Was this motor built to be all motor high compression in the first place? If so i think i would worry a little more about your p2w clearances.. Good luck
chrisa_1
Feb 12, 2010 04:56 PM
toooslow
Nov 12, 2003 11:08 PM
xonn
Mar 5, 2003 10:02 AM
RICHJ
Feb 18, 2003 05:48 PM
631 Teggy
Dec 15, 2002 07:25 PM
