boosted crx ?s
Old Oct 22, 2004 | 04:51 AM
rideblitz's Avatar
Default boosted crx ?s
hey i have an '88 crx si, D16A6 all stock internals. I want to know what a safe boosting level is? I will be using 450cc injectors and a S-AFC II, it is also going to be intercooled. I searched but couldn't really find someone with a decent match, i mean i saw some things but those were usually for like y8s or z6s and i have an a6.
also, if i were to get a good set of low compression pistons and rods, then what could be a safe boost level?
oh and what kind of times and hp can i expect at these levels?
Thanks!
Old Oct 22, 2004 | 06:24 AM
tgreaves's Avatar
Default Re: boosted crx ?s (rideblitz)
The a6 motor can handle a good amount of power.. The boost level is nothing, its how much power your putting out that matters.. What turbo are you using?
Old Oct 22, 2004 | 06:44 AM
rideblitz's Avatar
Default Re: boosted crx ?s (tgreaves)
its a t3 50 trim and .48 a/r
Old Oct 22, 2004 | 07:06 AM
tgreaves's Avatar
You can put out about 200hp with the a6 motor.. You have to get it on a dyno to find out where you at.. I would guess like 9-10psi or about..
La EF-8
Jul 31, 2006 09:38 PM
rideblitz
Oct 22, 2004 09:03 AM
MrHeeltoe
Oct 20, 2004 05:06 PM
comptonasskerry
Oct 17, 2004 05:07 PM
